seafoam-ing engine
Sorry to resurrect and old thread but I've always used seafoam in all my small engines and in the gas tank of my 05 883c but I'm due for an oil change soon and decided to put some in the oil tank. Now everyone is saying putting it in the oil tank is a bad idea, should I be worried about having done this? It was the first time doing this, my bike has 11k miles on it and havent ever had any oil issues like burning or leaking oil.
Do a (hot) oil change now, ride it for ~20 minutes to get the new oil hot and circulated, then change the oil a second time as well as the filter.
You cold also remove the oil return line from the oil tank and direct it into a bucket/bottle. Fire up the motor and watch BOTH the oil as it pumps into the bucket and the oil level in the tank. As the tank level gets low add fresh/new oil. Keep adding new oil as the level drops, until the oil going into the bucket changes from old oil to new oil.
Response to querry
Sea Foam is for cleaning the fuel injector / Carb system, it also cleans the combustion chamber from the inside with special stuff. Add to fuel, say 2 tanks should do it, save the rest for next spring.
Will help fuel economy by improving combustion.
I was getting 16KPL, after use climbed to 21KPL.
Enjoy.
pythonpaul
Exhaust System Topics
09-02-2008 12:55 AM
