883-1200 Conversion
Old 10-30-2006, 11:29 AM
olesalt's Avatar
olesalt
olesalt is offline
Default 883-1200 Conversion
Started stripping my '04 883 for the 1200 conversion. Upgrade will be 1200 jugs, Andrews N3 cams, SE A/C, V&H Straightshots w/ Quiet Baffles (maybe), carb rejet. Haven't made a decision on the ICM yet. I'm looking for a set of 04-06 1200 heads in good shape. I could send my 883 heads off to Headquarters or buy OEMs but those options are yet to be determined. More coming.........
Olesalt
Old 10-30-2006, 09:56 PM
springer_'s Avatar
springer_
springer_ is offline
Default RE: 883-1200 Conversion
Are you using stock 1200 flat top pistons or reverse dome pistons? We also can do the work on the 883 heads to accommodate the 1200 conversion. There are several options, if you would like to know more feel free to give us a call at the number below.
Old 10-31-2006, 12:30 AM
olesalt's Avatar
olesalt
olesalt is offline
Hey Springer,
The pistons are reverse dome 10:1 Weisco. I'll call you in a couple of days.
Olesalt
Old 10-31-2006, 01:16 AM
springer_'s Avatar
springer_
ORIGINAL: olesalt
Hey Springer,
Olesalt
The reverse dome pistons are designed to be used with the 883 heads. Using them with 1200 heads will dramatically decrease your compression ratio. The reverse dome is used to compensate for the smaller combustion chambers on the 883.
Old 10-31-2006, 10:19 AM
olesalt's Avatar
olesalt
olesalt is offline
Thanks for the tip Springer
mrfikser
11-06-2012 06:17 AM
kauffman_c
05-03-2011 10:27 AM
keithnhsporty
03-25-2011 08:12 PM
worthymccormick
10-03-2010 01:51 PM
mdrogers1
Exhaust System Topics
03-18-2008 08:47 PM
Quick Reply: 883-1200 Conversion
