1987 sportster 1200cc carb problem
Old 07-26-2011, 12:16 PM
randybecker's Avatar
randybecker
randybecker is offline
Default 1987 sportster 1200cc carb problem
i have a 1987 1200 sportster with a cv carb,i pull the choke out and the bike will run a couple mins and stall,push choke in and it wont run at all,pull it out and same thing it will run and then stall,it ran fine i rode it a few times and it ran fine now its acting up,i see theres no inline fuel filter just strait hose from tank to carb,anyones help would be great,thank you.
Old 07-26-2011, 12:58 PM
rjm729's Avatar
rjm729
rjm729 is offline
Probably just needs the carb cleaned. Get some seafoam. Drain the bowl, fill it with the seafoam, let it sit for a day or so. Then drain the seafoam. If that doesn't work you will need to take the carb off and rebuild it.
Old 07-26-2011, 01:04 PM
Mr. Wannabe's Avatar
Mr. Wannabe
Mr. Wannabe is offline
Plugged idle jet perhaps.
Old 07-26-2011, 04:20 PM
Mike07FLHTC's Avatar
Mike07FLHTC
Mike07FLHTC is offline
Your filter in in the tank on the end of the petcock. If your carb needs clean just cleaning the bowl with seafoam is a waste of time. You would need to clean the jets. Take the bowl off, take the slow jet and main jet out. They just unscrew. Spray them with carb cleaner blow them dry with compressed air. You should be able to see through them. The holes should be open clean and round.
Old 07-28-2011, 08:41 AM
randybecker
Default 87 1200 carb problem
the filter screen on the petcock is next,took hole carb apart cleaned everything,the carb seemed spotless,put it back on and no fuel,took the fuel line off carb and tank blew through line and it seemed like it was pluged then it was easy to blow through,turned fuel on and no fuel,hooked everything up charged battery ,hit starter button started and went to hit the gas and it bogged down and almost stalled,it would run until i hit the gas and bogged down like it was starving for gas,gas is going to the carb but it doesnt seem like enough,thanks
Old 07-28-2011, 08:49 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Hi randy, I used to live in Newport, NY.
Try starting the bike with your gas cap off to make sure the tank is venting.
Might be a good Idea to remove the petcock and visually inspect it, I would also drain the fuel out of the tank and see if its full of crap.
Old 07-28-2011, 03:30 PM
Mike07FLHTC
Did you check the float for a hole? Adjust the float level? Does it by chance have a later petcock with a vacuum port? Your 87 should have a accelerator pump . shoots gas through the carb when you give it gas. is the pump working? could have a hole in it . take the line off the carb with the fuel on it should run out the hose. if not petcocks plugged.
Old 07-29-2011, 05:14 PM
randybecker
Default 87 carb
i took the tank off and took petcock out some stuff on that sprayed it clean and blew it dry with compresor,put back together fired up ran good,rode it 4 blocks ran good but carb didnt sound right,got home and on the side of the carb where the throtle hooks up theres a little rod ,pump typ thing with a little rubber boot,theres gas dripping out of that not much doesnt really drip till its sitting at idiol,im sure enough to start a fire if driven a long way,any info on that,good thing running and is ridable but caution comes first,thanks
Old 07-29-2011, 08:38 PM
xFreebirdx's Avatar
xFreebirdx
Thats your accelerator pump, get a new diaphragm for it, plus you mat need a new O-ring for it it it has one. Get a new rubber boot for it to if you think you need one.
the parts for it are cheap enough.
87sportster
General Topics/Tech Tips
14
01-20-2024 07:25 PM
pacman552sd
Carburetor Related
06-03-2015 10:39 PM
trickassfoo
Exhaust System Topics
17
07-10-2013 06:40 PM
TXbobber
08-07-2012 09:43 PM
wareagle104
03-15-2008 07:54 PM
Quick Reply: 1987 sportster 1200cc carb problem
