Popping and backfiring
Old 07-27-2011, 10:34 AM
slipvayne9278's Avatar
slipvayne9278
slipvayne9278 is offline
Default Popping and backfiring
Couple weeks ago, i went riding was fine for about 3 hours then all of a sudden it started backfiring and popping
Now i hear small pops coming out of carb area, the backfiring comes out of exhaust
When i give gas hard i get a quick pop then it goes, if i hold the throttle steady at a slow speed. It jerks, like hiccuping.
If i give it gas it goes, then throw in clutch to switch gears only to hear shotgun backfires coming from exhaust
It is just strange to me to start out of nowhere, any ideas? Im new so please be gentle thanks guys
Old 07-27-2011, 11:07 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Can be anything from a dying battery, failing charging system, bad seals on the intake or carb, and the list goes on and on. Great section in the troubleshooting area of the service manual about it.
Plus you also left off all the info about your bike? Is it a Honda Fury?
Old 07-27-2011, 11:10 AM
slipvayne9278
No lol its a 91 sportster 1200,the charging system recently failed. But i fixed that and battery is now fine
Old 07-27-2011, 11:32 AM
xFreebirdx's Avatar
xFreebirdx
Check your battery cables. make sure they are tight on all 4 ends........
Old 07-27-2011, 11:35 AM
slipvayne9278
I did that, but will recheck
Old 07-27-2011, 11:56 AM
mwegryn's Avatar
mwegryn
mwegryn is offline
It's been a little bit since I've had a carbed bike...so I'm just taking an educated guess here. Any chance the jets are gunked up? Popping on any bike is usually, but not always a pretty good indicator of a lean condition from what I've learned. I would also check your plugs for the heck of it too.
Old 07-27-2011, 12:04 PM
slipvayne9278
I was told to put hotter plugs in, to burn off the excess gas, does this sound right?
Old 07-27-2011, 12:22 PM
JohnnyC's Avatar
JohnnyC
JohnnyC is offline
Often popping and backfiring is caused by the timing being off the mark.
Take a look at your plugs too. A fresh set could be all you need.
Old 07-27-2011, 12:28 PM
mwegryn's Avatar
mwegryn
mwegryn is offline
I don't know if I'd go that route especially if it was running fine prior to your recent troubles. Too hot a plug and you run the risk of pre-ignition combustion. Just pull yours and see how they look. There are a lot of illustrated guides online to help you read them (I put a link down below). If they are cruddy looking, just replace them, it was time anyhow and they are cheap. It may not be your problem at all, but it's worth a look since it only takes a minute.
http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
Old 07-27-2011, 01:03 PM
Twiste's Avatar
Twiste
Twiste is offline
Check the simple stuff first. Check gas and tank. Took me 3 tanks to run through some bad gas I got a couple years ago.
Quick Reply: Popping and backfiring
