Rev Limiter
Rev Limiter
Does anyone know if a 2005 Sporster 883 has a rev limiter. I am pretty sure it does, but I know that prior owner had a new exhaust, intake and jet kit installed...that wouldn't effect any stock rev limiter would it. I have heard the 883 is a higher reving engine (for a Harley) but don't want to blow it up
It does, and I think it's somewhere around 6,200RPM. If you're curious, put it in second and red-line it. You'll know when you've hit it. A new ignition module (ie. Screamin' Eagle) will allow you to push it to about 7,200RPM, but I would say that's unwise unless you've got enough engine work to compensate.
It does in fact have a rev limiter. Stock for an 883 should be set to 6200rpm. This prevents self-destruction of the engine through valve-float, excessive stresses, and other problems that come with running an engine not built for that high of a speed.
The only way to change your stock limiter would be to adjust the ignition module itself. This was likely not done with what sounds like a standard stage 1 for your bike. You'll be fine where it's at.
