DIY Step by Step with photos: DK coil and ignition relocate with wire tuck, no lift.
#101
Originally Posted by ylwf3vr
Maybe I missed it but where do you all put the horn??
#102
Received 3,930 Likes
If you use the small round horn, it goes between the downtubes....check this LINK
Yes, if you don't want the round horn, the cowbell won't fit up front between the downtubes.
I've seen guys take the horn out of the cowbell and mount it behind the rear cylinder, also have seen them mounted on the swingarm.
I've also seen one person mount the cowbell Under the relocated coil. However, I am not at all sure that the Coil Relo bracket will hold up to that extra weight/leverage/vibration...some thing for the cowbell bracket, not sure how long that would last with the extra vibration.
#103
Bayou FLHR-M8-128" (08-25-2021)
#104
#105
In the place you see the round horn in the picture here-
Rob Robb (06-06-2017)
#106
See post 312
https://www.hdforums.com/forum/sport...l#post14369577
#107
#108
For install instructions of coil & key relo, email us at Support@DKCustomProducts.com and ask for a copy of the 95-03 coil instructions and copy of the F6 instructions. We'll email them to you.
You don't remove the entire bracket in pic 1, and on the 95-03 there are several places to put the key, below is a pic of one of them.
But it is all in the instructions we can email you.
#109
