Engine hit rev limiter!!!!!!!!!
Old 10-19-2011, 12:28 PM
Cromosappien's Avatar
Cromosappien
Cromosappien is offline
2nd Gear
Default Engine hit rev limiter!!!!!!!!!
Almost dropped my 1200 Sportster the other day and in the process of stopping it from falling I ended up with full throttle for about 4 seconds (in neutral, warm engine) with the engine revving against the rev limiter. Engine seems fine since, I guess that is what the limiter is for. Any thoughts?
Old 10-19-2011, 12:32 PM
poisonthesteve's Avatar
poisonthesteve
poisonthesteve is offline
i've hit the rev limiter in many cars, never on my bike, with no consequence. that being said i wouldn't make a habit of it either.
Old 10-19-2011, 12:49 PM
SDr6's Avatar
SDr6
SDr6 is offline
I used to bounce off the rev limiters on my sport bikes... never on my Harley
Unless Harley engines are **** there's nothing to worry about.
Old 10-19-2011, 12:52 PM
Shredding rubber's Avatar
Shredding rubber
Shredding rubber is offline
The rev limited is set lower than the max the bike can handle. You theoretically could bounce it off the rev limiter all day(if you could keep the engine cool enough) without damage however I don't suggest doing it. The ecu pulls timing and cuts off fuel to achieve the rpm drop. Dont sweat it. Now get out there and ride
Old 10-19-2011, 01:55 PM
Cromosappien
2nd Gear
I was, I is and I will be!
Old 10-19-2011, 02:09 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
I hit the rev limiter in 2nd gear all of the time when I am chasing after my buddy on his ZX-14.
Old 10-19-2011, 07:46 PM
WVleo's Avatar
WVleo
WVleo is offline
I thought that was when the bike told You to shift !......WVleo
Old 10-19-2011, 08:13 PM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
My Kawasaki has found the rev limiter on many occasions. No issues ever. The thing is supposed to stop the motor from spinning beyond what is safe. Should be no issues for you.
Old 10-20-2011, 06:45 AM
schwingding's Avatar
schwingding
schwingding is offline
Dude, the rev limiter is a shift indicator! Use that fugger! I hit that thing all the time (it's REALLY fun on the VROD at nearly 10,000 rpm)
Old 10-20-2011, 08:58 AM
UnNatural's Avatar
UnNatural
UnNatural is offline
Yeah no worries. I used to hit the rev limiter on my R6 on a regular basis, if you time it right you can shift without using the clutch.
Quick Reply: Engine hit rev limiter!!!!!!!!!
