Side mount license plate
use the mount you already have
I used the existing plate mount off of the fender. I just heated it up and hammered the **** out of it until it was flat, then drilled a hole to fit the lower shock bolt, then put two holes through the plate, and done. Total cost $0 unless you by a can of rattle to paint it after.
Still waiting to mount a light for it though... I know they make cheap LED bolts with lights on them for only a couple bucks.
I run RK shocks...and I made a plate and it is mounted to the upper shock body...not going anywhere now.
I know one guy complained and got a replacement....guess what happened to that one?
Mine broke off on the way down to FL Christmas 09' in PA....so by time I hit the FL state line I already had in mind what I wanted to do and didn't want anything to do with another road6plate holder.
I know when I was on their website I don't think they had area for customer reviews. I bought it off Ebay but 6 months later you can not leave negative feedback.
http://xlforum.net/vbportal/forums/s...ighlight=road6
I added four LED bolt lights and this is what I have now. If you look closely you can see the two large zip ties. One of them is at the very top of the RK rubber boot where it goes around the upper shock body and the top zip tie goes around the metal upper shock body only about 3/4" above the other zip tie. I wanted two to help prevent it from spinning...and it works even as close as they are together.
With the LEDs on:
My side mount license plate set-up
This is my 07XL1200C. I bobbed it out to a simple, old school set up. I removed a lot of stuff. I replaced the stock seat, replaced handlebars & risers(Drag Specialties), grips, mirrors, removed belt guard, new tail light w/ led bulb, S&S Stealth air intake, Vance and Hines Straight shots, Joker Machine Side mount speedo, tons of simple mods. Overall a great bike.
My advice? You could go cheap and do what I did. Get a new location for the license plate, straight/curved, or a horizontal one, depending on your state laws. Also, ypu will need to get 2x license plate bolt lights and wire them up, you're good to go. Not hard at all. Here's some pics to elaborate.
I lost two brackets to my hardtail struts before going with DK's
http://www.dkcustomproducts.com/Lice...DK-LPR-HOR.htm
