Brake Lights always engaged
I searched the forums and can't find anything to help troubleshoot this issue. I have a 1200 converted Iron and I just noticed my break lights are always on. I have checked fuses and bulbs and I cannot figure out why the brake lights stay lit up. Has anyone had any issues with this? I really don't want to take my bike to the Stealer.
Scuba 10 is right, its the switch. I just put my apes on tonight actually, i grabbed the brake lever and heard a little crack, didnt think anything of it till i went out for a lil test run and noticed the same thing. luckily my apes came from hill country customs with new controls. I had to splice in the old switch and give a lil more caution while re installing. You can probably get a new switch from harley pretty cheap, wouldnt try fixing the one you got if it is broken, sounds like a great way to get rear ended ha. good luck.
you'll just have to snip the two wires, ones red with a yellow stripe... cant remember what the other one is but regardless, you just need a little solder and some heat shrink. if you dont have another switch that will be the only problem. there is a little copper piece that goes between the switch and the housing the keeps the plunger pushed tight into the hole where it makes contact with the brake handle, just make sure you keep track of it.
2010 converted 1200 Iron. The brake lever makes contact with a dust boot. Kinda hard to tell looking at the manual. I had the housing apart earlier and saw the brake lever making contact with the boot. In the manual it shows the stop light switch as a square object but doesn't get real specific. I guess I'll have to tear it apart tomorrow so I can see if I can see what's going on in there.
