2010 883 Low Exhaust question
Old 11-26-2011, 04:59 PM
millzog's Avatar
millzog
millzog is offline
Big Kahuna HDF Member
Default 2010 883 Low Exhaust question
Will there be a problem with just replacing the slip on mufflers and not adding a new fuel injection module ?
Any feed back would be great ,
Thx .
Old 11-26-2011, 05:01 PM
Brion B's Avatar
Brion B
Brion B is offline
There should not be any problem by just adding slip on mufflers.
Old 11-26-2011, 05:15 PM
millzog's Avatar
millzog
millzog is offline
Thanks Brion on your input !
Old 11-26-2011, 07:29 PM
ColoHarleyGirl's Avatar
ColoHarleyGirl
ColoHarleyGirl is offline
Thx .
My two cents. I believe there is no issue with just putting on the slip on mufflers. However, any time you change original equipment you will change the way the engine runs (rich versus lean). You really should have your ECM retuned. Your dealer can use a factory preload or buy the screaming eagle super tuner and have your bike dyno'd. If you change the exhaust you might want to change the air cleaner. This is what HD calls its Stage 1 upgrade.
Old 11-26-2011, 07:37 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
ZERO problems with just changing mufflers.
Old 11-26-2011, 08:46 PM
barrygreen's Avatar
barrygreen
barrygreen is offline
No problems changing the mufflers and or cleaner, won't run any leaner than stock.
Some type of tuner or fuel control device will make it run better. But just changing mufflers you are fine.
Gelly
04-02-2019 09:56 AM
I8AGSXR
01-13-2018 08:05 AM
tallj2000
03-18-2015 04:45 PM
brummie
09-25-2011 09:17 PM
RPS1981
02-03-2011 08:18 AM
Quick Reply: 2010 883 Low Exhaust question
