2012 Sportster low rider issues
My 1200 Custom was very consistent and averaged 45 mpg in mixed city/country/highway riding in stock configuration. After the stage 1 upgrade it is averaging around 42-43. I have a 4.5 gallon tank and the light is likewise consistent on coming on steady after I've used 3 gallons.
We have a superlow and so does a friend of ours, and if the key is left on for any amount of time at all without it running for some reason it misses the fuel light up. After four or five times of starting and stopping it it seems to clear it up. Our light comes on at about 1.5 gal. left in the tank, and it gets around 50 MPG. We really like ours and hope you get yours fixed up.
could you explain this a bit more, would love to bring this up to the techs.. The tech there doesnt seem to be the most knowledgeable from what ive seen so far.. when i first brought up the fuel light issue he said i had a 2 gallon tank and it goes off half way.. i said i had a 4.5 tank and he said hed have to read his manual.. if they cant find the problem ill take it to another tech in another city..
im taking it in tomorrow if they let me...
Received 3,940 Likes
Go to a different dealer. One with a semi-competent mechanic vs. one that tells you you have a 2 gallon tank.
The light should NOT be coming on at 70 miles on a 4.5 gallon tank IF you have filled it up all the way. Make em fix it. I have 3.3 gallon tank on my 883 and the light rarely comes on before 90-100 miles and it has a 3" tank lift.
Are you sure the jerking/hesitation is not from being at too low an RPM when you go to accelerate? Easy way to find out is to pass the "100 mile" mark you mention and get those RPM's up there and then accelerate hard.
With the fuel injected bikes there is always going to be a little hesitation at low speed, low rpm acceleration...they come too lean from the factory.
First, let me say I don't have a fuel injected bike and I don't have a manual for one, so I'm unfirmiliar with the exact arrangement you'd find in a Sportster. However, on the Big Twins, I've seen a pick-up hose with a hole in it from rubbing on the fuel pump/mount inside the tank. I'm only guessing, but the symptoms you describe seem consistent with what I've seen before. It makes sense that a pick-up tube with a hole would become less efficient and cause fuel delivery issues at the point where the fuel level goes below the hole (100 miles). Perhaps someone with a Shop Manual or a Parts Manual will chime in to confirm or repudiate that a pick-up tube/hose exists in the Sportster system.
I look forward to hearing the outcome of your dealer visit tomorrow. I could be completely wrong and it turns out the muffler bearings are causing the problem (sarcasm, yes).
No it happens at both low RPMS and high.. its a 2 second hesitation with a hard re connect of power... it throws me around once it connects.. if this would be normal i would sell this bike in a heart beat.. its scary as hell.. its comparable to downshifting on the highway to 2nd and opening throttle all the way except the bike doesnt engine break.. its a hard thrust forward.. this has happened at 60 miles and hour.. the bike wont relax at all past 100 miles..
Id love to see a diagram of this.. i have a 2 year warranty on it fortunately..
I would get it into a competent dealer asap. Make sure you got over 100 miles burnt on the tank so that they can duplicate the problem.
Here is a link to a diagram that may be useful-
http://partsfinder.onlinemicrofiche....dmc&A=747&B=42
Pretty much every part on your bike is in diagram form on that site.
from the manual
the closest I could find in my repair manual under troubleshooting, is the following. "starts but runs irregularly or misses"-
spark plugs bad
plug wires
plug gap too close or wide
faulty coil, ecm, or sensor(tmap,ckp,et,or O2)
battery nearly discharged
damaged wire or connection at ecm, battery, or ign. coil
intermittent short due to damaged wire insulation
water or dirt in fuel system
fuel tank vent system plugged
air leak at intake or air cleaner
partially plugged fuel injectors
damaged intake or exhaust valves
weak or damaged valve springs
incorrect valve timing
Most of these are going to be a miss, not sure what kind of maladies a plugged or misconnected tank vent will cause, though. Your battery and connections are suspect as well I'd find a dealer who at least has a tech who says "sir, I've got to do some research on this one, and then reads the manual before he speaks to the customer about chit he's not familiar with.
spark plugs bad
plug wires
spark plugs bad
plug wires
spark plugs bad
plug wires
But.. when i took it in the tech got more involved with me about the problems and wanted to know every detail, so maybe he had a crappy morning or something.. its funny both techs from both shops thought it was a 2 gallon tank... lol this is funny and rediculous.
this day has been terrible i even something dropped the bike.. i was going into a really tight turn into a parking lot at a slow speed.. i underturned and went into muddy garden beside parking lot road.. locked the front and bike went down.. my addrenaline kicked in and pulled it right up before the tank layed down.. only marks are on the peg mount.. the peg mount or peg is slightly tilted up compared to the other.. its very slight.. i asked the part guy how much (told him a speed bump did it, probably doesnt believe me lol) they said about 20 bucks.. im glad it was only the black mount underneath the bike, i looked it over like a hawk.. fortunately the entrance lot went into the dirt or it could of been worse, its a badly designed road but it was my fault.. I was only going about 5mph.. im still learning on my super slow tight turns.. i took the MSF class part 1.. part 2 i can do now that i have a bike.. but they are closed till spring. sorry for the long story lol
You guys/gals have been great
Don't worry about dropping the bike, everyone goes down at some point. The good part is you walked away from it with no really big damage to yourself or the scoot.
The MSF class is well worth taking. The good thing is that winter is setting in so you will have winter weather downtime to get the bike sorted out and be ready for spring.
Did you try to stomp the peg back into place? They should pivot and the bolts may just be a bit tight.
