OK, WTF? Speed sensor install
So I finally got my new speed sensor because my speedo was not working. It lit up and the engine light and everything else works, So I assumed it was the speed sensor. When I pull the codes on the bike using the speedo The only code I get is D05SET which ac according to the the manual is a speed sensor short? something like that. Anyhow, I try to clear the code within the speedo but as soon as it clears it shows the error again. I was reading the manual it is says that the code nees to be cleared with a scanner or it will clear after 50 start cycles. Does anyone have any insight on this? Have you ever had to change the speed sensor and clear the codes? if so How do I do it? Should the the speedo work even though its still showing the code? Please HELP!!!!
Just to let you know. I recently had my speedo/odometer, self canceling turn signals all quit. The speedo was still lit up and it cycled through the trip meters. I had NO diagnostic codes. i took the bike into the dealer and it was a faulty VSS. they replaced it under warranty and has been good since.
yea, I got the new speed sensor and installed it....nothing. I read through the manual that the code will reset after 50 start cycles, so I decided to wait till I hit that. I installed some pipes on the bike and would ride around without realizing that the damn Speed sensor wire was sitting ON THE PIPE!!! it melted the wire and exposed some of the copper wire. Since then I said eff it and have had a non operational speedo. I plan to take the sensor back off and re-solder it, it should be fine....I am thinking that my actual speedo may be bad. If thats the case I am going to say screw it and just run my tach. Does anyone know hit to manually reset the codes?
Eh I had it at the dealership today for turn signals and asked them to fix the speedometer. They put on a new VSS. It got better. It was to the point where 1/2 my ride to the dealer (1-1.5 hours away) was a 0mph speedometer. Most my ride home I had a MPH reading. However it did blip out twice then come back. I'm going to monitor it over the next few rides and see what happens. If not I'm calling them back.
Nothing like spending $90 and still having problems.
Im not unfortunately. I hope I don't have to get one but Ive been eyeing up a dakota digital for over a year now but 325 eek. Thatll hurt the wallet
