No Power (Not battery related)
Old 12-29-2011, 10:46 AM
Buckley29's Avatar
Buckley29
Buckley29 is offline
Default No Power (Not battery related)
Hey all,
I just finished stripping my bike down and doing a complete engine rebuild. I have everything put back together for the most part (without any left over bolts or pieces ) except I have one little problem. When I turn the key in the ignition, I have no power whatsoever. No lights, no dash, no horn.
So far I checked the voltage on the battery (12V) and checked and rechecked my battery connections. I didn't touch any of the front end wiring, but did have to disconnect the engine side connectoins such as the speedo sensor and cam position sensor to remove the engine so im guessing the problem is back there somewhere.
From my understanding the power goes through battery to the starter, then to the main circuit breaker, and from there up to the ignition where it is dispursed out to the lights/horn/ignition module/ect. I double checked the connections at the starter and they seem to be tight and corrosion free. Any other ideas what I can do next? I'm a bit stumped, electrical systems aren't exactly my nitch haha.
Thanks guy.
Old 12-29-2011, 11:06 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Have you traced power up to the fuse box with a (light) tester? You need to find out whats hot and whats not. Start back at the battery again and work your way up..... The speed sensor or the cam position sensor would not keep the motor from turning over......
You also need to post the specs of your bike IE: Year and model.
Old 12-29-2011, 11:27 AM
Buckley29's Avatar
Buckley29
Haha I was hesitant to post my model/year since I drive a 2000 Buell Cyclone. I know a lot of Harley enthusiests arn't big fans.
How would you go about tracing the power? What junctions would you test at?
If I bridged the terminals of the circuit breaker with a wire could I use that to bypass it to rule that out as the problem?
Old 12-29-2011, 11:53 AM
run1fsr's Avatar
run1fsr
run1fsr is offline
If the circuit breaker is tripped, it is tripped for a reason ... dont jump it out. I assume that you have a manual with electrical schematics. Get a good electrical meter and start tracing out components on the ignition system of your bike.
Old 12-29-2011, 11:57 AM
Buckley29's Avatar
Buckley29
Alright I'll take your advice on that one and won't bypass the breaker. I'll buy a light tester after work today and go to work.
I have another question tho if you guy dont mind. Could a voltage regulator problem cause all power to be cut?
I do have a manual, but the schematics in the one I downloaded are awful haha.
Old 12-29-2011, 12:02 PM
run1fsr's Avatar
run1fsr
run1fsr is offline
Buy a decent electrical multi meter ... not a light tester.
Old 12-29-2011, 12:05 PM
Buckley29's Avatar
Buckley29
I do have a multimeter but wouldn't it be easier to check for current in the wires by piercing them with a light tester? Not quite sure how I would go about testing the wires with a multimeter without actually stripping the insulation (it has a much broader tip).
Sorry I don't have much experience with electrical systems.
And thanks for the quick replies.
Old 12-29-2011, 12:16 PM
RATROD HOG's Avatar
RATROD HOG
RATROD HOG is offline
dont cut wires just check the end of the connectors for power (12V)
as said DONT jump no relays
Old 12-29-2011, 12:17 PM
RATROD HOG's Avatar
RATROD HOG
check all fuses?
i mean not look at them test with a meter
Old 12-29-2011, 12:30 PM
Buckley29's Avatar
Buckley29
Alright thanks guys, i'll give that a shot this afternoon and i'll get back to you.
Im anxious to get this thing started to see if the engine rebuilt and new cam position sensor fixed my missing problem or not :P
Quick Reply: No Power (Not battery related)
