Quick Trick Needed: Removing Peg Clip
I thought I'd ask some of you more seasoned folks out there a quick question about removing my stock pegs. Maybe someone can help:
As you know, the stock foot pegs (mid) are attached to the bike with a bolt which goes through the bracket attached to the bike, the peg and the spring washer. It's then secured by a lovely little metal clip which one would think would come right off with no problem. The clip goes around the entire end of the bolt, ensuring that it stays on and the entire assembly stays intact.
Does anyone out there have a quick trick for removing that metal clip (without destroying it, of course)?
Removing the clip is the key for swapping out the stock foot pegs for aftermarkets. I did a "dry run" this evening and was successful but bent the clip slightly as well as put the spring washer back in incorrectly. I now need to remove the clip and do it all over again to properly place the spring washer back so any insight would be appreciated.
Oh, and by the way...I'm not a technical dude so I'm sure that my parts references are way off.
Thanks in advance for any help.
Ok, I went out in the garage and looked at the Nightster to see what you were talking about. If you are talking about the clip that goes on the pin that secures the peg to the mounting bracket itself, that is called an "external retaining ring". There are 2 ways to take those off....first is the correct way. There is the correct tool for that which makes it a breeze to take that clip off and put it back on. The tool looks like small pliers and has 2 pins at the end, which go into the holes on the clip, then you squeeze and it expands the clip....viola...its off. If you aren't planning on putting it back on, then use a small flat head screw driver and push it into the "split" between the 2 holes and twist and odds are that thing is going to shoot across the garage somewhere. LOL!!
Wouldn't it be easier to take the peg off at the frame instead of dealing with the clip? I just did that to paint the motor.
Good luck with your project man!!
Received 3,939 Likes
Since many people do not have a pair of snap ring pliers they end up losing or buggering up the rings when they pry them off with a screwdriver.
That is why we include a pair of new rings with each pair of foot pegs we ship out.
The right tool for the right job makes all the difference. If you are going to do much wrenching on your bike, you will find that you will acquire a much better set of tools in the process. If you try the screwdriver technique you will definitely bend the ring out of the plane. A pair of reversible snapring pliers (they can push out or in as the application requires) from Sears is inexpensive and good to have on hand.
