Relocating the rear mastercylinder (pre 04)
Old 01-01-2012, 12:32 PM
mreed's Avatar
mreed
mreed is offline
Default Relocating the rear mastercylinder (pre 04)
I do alot of these so I figured I'd share some pics.
If you have removed the sprocket cover (and have forward controls) you'll need to find another way to mount the master cylinder. I'm sure there are 100 ways to do this but this is what I've found to be the easiest.
It's simply 2 pieces of angle welded together and then shaped with the flap wheel on a 4" grinder.
Replace 2 of the bolts in the cam cover with grade 8 all thread, slide on the bracket and secure with nuts. I use acorn nuts to keep it clean. You may need to cut a couple spacers to use between the bracket & cam cover to help align the plunger with the pedal. I use a stock mid control clevis to attach the pedal to the master cylinder and that's it.
I've done these to convert rear mechanical drum brakes to modern hydraulic, for better fitment of custom pipes and just for looks...
Thanks.
Old 01-05-2012, 08:06 AM
run1fsr's Avatar
run1fsr
run1fsr is offline
Great idea. If I were mounting forward controls I would make this mod.
Old 01-05-2012, 05:23 PM
bmxatv's Avatar
bmxatv
bmxatv is offline
very clean mike. so is that freaking cam cover chop!
Old 01-05-2012, 08:24 PM
mreed's Avatar
mreed
mreed is offline
Thanks but I cheated. A friend of mine made an attachment for his mill table that a cam cover bolts to. It was basically just watching it happen after that.
Old 12-15-2014, 06:34 PM
cplmackk's Avatar
cplmackk
cplmackk is offline
Stage II
Thanks.
Hey i like the bracket you built and i need to relocate my master cylinder for a kicker kit. Do you have any more pictures the ones on here have been removed.
Old 10-26-2018, 12:14 PM
Luckystar1384's Avatar
Luckystar1384
Luckystar1384 is offline
Stage I
Smile Hey I love this idea wish all your pics worked
Hey i saw your post about relocating rear master cylinder and i wish i could see all your pics can you give me some more insight into this and maybe send me all the pics. I have a 2001 Sportster and i would love to do this and get rid of stock trans sprocket cover. My email address is Luckystar1384@gmail.com
Old 11-24-2019, 12:45 PM
Jay Woodward's Avatar
Jay Woodward
Jay Woodward is offline
Stage I
anyone find these pictures? Please send to jay@jaywoodward.com
jay
owenewowen
09-24-2018 09:08 AM
nc883
01-01-2012 11:19 PM
atrain68
05-07-2011 08:04 AM
icecaps
11-08-2008 06:59 PM
skim
04-08-2008 11:54 PM
Quick Reply: Relocating the rear mastercylinder (pre 04)
