Bassani pro street exhaust
They actually make 2 versions of the pipe, one for mids and one for forwards. Both are available in black or chrome and with straight cut or slash cut tips.
Forwards:
Mids:
You can see that the front header is a different shape, you can use mids or forwards on the first model, but strictly mids only on the second model, probably due to the location of the mounting bracket for the forwards.
Note: first is 07+ , second is 04-06, just couldn't find a good side shot of the 07+ for the comparison.
Seeing I'm running mids on my bike, I'm gonna opt for the second model, I think its more esthetically pleasing and "flows" better.
Forwards:
Mids:
Once I figure out performance, I'll get someone with more appreciation of aesthetics to help me select what looks good from the top performers
Definitely correct, from a strictly performance view, 2-1 is the way to go. Especially with the bobcat, heard nothing but good about them.
Lots of times we choose form over function, if I wanted maximum performance I wouldn't have bought a balloon tired "48".
2-2 drags compliment the particular look I'm after.
And from what I've read, the Bassani pro streets are actually a pretty well performing pipe, compared to the usual 2-2 V&H Straigh Shots.
Aesthetically pleasing sure but how did you determine it flows better when you lose scavenging? I hear lots of people say that but I am trying to determine, before I pull the trigger in spring, how the came up with that. I am looking for the highest flowing AC and best flowing set of pipes. I could care less what it looks like or what it sounds like or how impressed others are with it so I am looking for hard facts on how something works.
From the reading that I've done, I'm pretty sure the D&D Bobcat is a top contender from a performance standpoint. I know with exhaust design from my motocross background, there's usually some compromise of where you want the power. One particular design will give you max Hp on WOT, but no bottom end, the other will deliver tons of torque down low but fall flat on top. Then there's everything in between, just depends on what you want the power for.
From D&D's website:
The D&D Bobcat Sportster pipes are built for Harley-Davidson Sportsters for performance, torque and soul-satisfying tone. Available in black or chrome with polished aluminum, black, or carbon muffler. The stepped 2-into-1 exhaust system comes with full heatshields. Enthusiasts will experience as much as 10% increase in torque and horsepower (with hi-flow a/c and tuner). The Bobcat Sportster exhaust system was created on the dyno to dial in the performance where you need it most... off idle and in the passing zone. The pipe delivers increase power and torque across the entire RPM range.
Haha, in the statement "I think its more esthetically pleasing and "flows" better." Flow was referring to the shape of the pipes in relation to the bike, pure looks. Compared to the other design for forward controls. NOT exhaust flow.
From D&D's website:
From D&D's website:
I believe Bassini was also recommended but the clearance was supposed to be worse but the question is whether I will lean at that angle or not. IDK.
As to performance, I think top HP isn't that good since I am not full out racing where I am constantly at WOT. I would believe low to midrange torque is going to be best especiall when the wife gets on it. I am about 220 with the gear and the wife will be no more than 120
The performance aspect of the Bassani's are great too......If you look at the pictures, you can see that the pipes are "stepped" using three different size pipes and have baffles in the last larger pipe section. The "stepping" and baffling mixed with the shape & length of the pipes causes you to not loose any back pressure so that you have your low end torque, but still flows alot more air for your WOT Hp. Bassani has been in the "performance" exhaust manufacturing & design business for quite a while.
And for air cleaner, I'm running the Big Sucker II.
I got no problem taking off 2-Up.
You could always buy the 2 available sets and ship one up here to a fellow forum member..... Just sayin'
