Problem removing forward shifter
I finished the right side mid control installation, and now I'm having trouble with the left. I removed the shifter pedal and linkage, but can't get the armature off the shifter shaft. I removed the bolt that holds it in place, even squirted some pb blaster on it, but it still won't budge.
Any advice on how to get it loose?
Here's a picture before I started:
I shouldn't have referred to the shift lever as new (new to me), since I got it from some guy on craigslist who had installed forwards on his 2001. It could have been cracked from when he took it, or I could have put too much force on it trying to get it installed, though it shouldn't be that easy to break steel.
New shift levers are around $20 on ebay.
Guess I wasn't gonna ride in this blizzard anyway.
Then it isn't too bad.
Without a gear shift? Not a good idea. With a gear shift? Sure.
