Charging a dead battery
Old 02-24-2012, 03:01 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Ragnar Danneskjöld is offline
Probably true, but always worth a shot before buying a new one.
Old 02-24-2012, 03:16 PM
1CdnHD's Avatar
1CdnHD
1CdnHD is offline
Originally Posted by X04D
I was wondering if that were possible.
Yes, you can 'trick' the charger by momentarily jumping your battery with a good battery.
Old 02-24-2012, 04:06 PM
PigInaBlanket's Avatar
PigInaBlanket
PigInaBlanket is offline
If you end up needing a new battery you can get a Eastern Penn manufactured battery from Advance Auto for $39.99 after using the code big15 at checkout. Here's the link for your battery on their site http://shop.advanceautoparts.com/web...8_A%7CGRP60054____
Better than the $115 HD wants for their battery.
Old 02-24-2012, 04:17 PM
1200Cdriver's Avatar
1200Cdriver
1200Cdriver is offline
If the battery sat dead for a while the sulphur has settled out of the sulphuric acid and shorted the plates together. That's why its important to keep them fully float charged at about 14.4 volts. A CVC that keeps them at 15.6 will boil the water off over time.
Old 02-24-2012, 04:50 PM
Ragnar Danneskjöld
Appreciate the help. Unfortunately, in Canada, it's impossible to get a battery shipped here for less than the dealer charges.
Old 02-24-2012, 04:55 PM
emperor wurm's Avatar
emperor wurm
emperor wurm is offline
I have jumped many a bike with my truck. Just jump it, let it run for a while, hopefully it was cycle somewhat of a charge, then throw it on the tender. unless its been sitting for a hellva long time, you should be good.
Old 02-24-2012, 07:35 PM
1CdnHD's Avatar
1CdnHD
1CdnHD is offline
http://www.eastpenncanada.com/contact_us.php
Don't go to the Dealer, a OEM Harley battery is a Deka in a black case with an HD stamp on it.
Old 02-24-2012, 07:48 PM
TheJoker78's Avatar
TheJoker78
TheJoker78 is offline
I have used my truck to jump start my old Crossbones but then I needed to replace the battery as for some strange reason it just killed it. According to HD that's where I went wrong, so instead of ordeing a new HD battery I went with a new battery from JP cycles.
Much better then the stock one I had, hope it helps.
Old 02-24-2012, 08:08 PM
Ragnar Danneskjöld
I'll look elsewhere but I have no vehicle so I won't go too far out of the way to save $10-25. But I'm sure some stores will have 'em.
Old 02-24-2012, 08:14 PM
delane's Avatar
delane
delane is offline
Originally Posted by John Harper
Borrow a battery charger, use the 2A setting. I'm not sure I'd try to jump a motorcycle battery with a car's charging system. Too many amps could blow it up.
John
I have done this before (only once) and that is exactly what happened. Had to buy a new battery.
Quick Reply: Charging a dead battery
