What can I look forward to in the next 30,000 miles?
Hi everybody. So I bought a '08 1200C with 21k on the clock. Being that I may have to keep it a few years to pay it off, I was wondering, what kinds of service or work may I encounter or have to plan for with this bike in say the next 30,000 miles or so? Can a 1200 engine make it to 50,000+ without any pricy repairs or overhauls?
The stators in Sporties seem to have a life expectancy of around 25,000 miles, so you may have that coming soon. Prices vary based on local labor rates, but expect it to run $400-$500 to have it fixed, assuming you can't do it yourself.
The Spring Plate in the clutch pack is another weak link, typically lasting 30,000-40,000 miles before the brass rivets let go. Once the rivets completely let go, you're looking at $800-$1,000 for a complete clutch basket. However, replacing the Spring Plate is relatively inexpensive if you have it done during the stator replacement since the clutch pack has to come out anyway for that anyway.
Those have been my 2 major recurring issues in 80,000 miles.
Received 3,940 Likes
Tires a few times in the next 30K, and probably brake pads also.
There are no early warning signs for stator failure. Your check engine and battery light will come on. When that happens, get home, or to a service facility as quickly as possible. Sometimes you might have as much as a 100 miles before the battery is totally dead. Other times, you might have as few as 10 miles.
Changing the primary fluid will not affect the clutch life. It is a bad design. I use the best primary lubricant changed religiously. But that will not help with a poorly designed clutch. Here is a thread I started a couple of years ago about the clutch.
https://www.hdforums.com/forum/sport...tch-alert.html
why does harley design stuff to fall apart? Why the hect would they use brass in a clutch assembly?
How long does a typical motorcycle clutch last? Say in a metric crusier?
I dont like the idea of having a motorcycle that I know is going to break down. Makes me want to trade it in on a yamaha. I'm sure yamaha isn't using brass in the clutch.
In 6 years of riding I;ve never had a motorcycle break down so I kind of have high expectations.
Is it a good idea for everyone to just replace the clutch with a SE clutch and stator at 25,000 miles? Maybe I should just buy an extended warrenty when I hit 20,000 miles?
