Horse power of a Mild upgraded 883 (2000)
Wondering if anyone knows what the stock HP is on a 2000 883 sporty. Well mine isn't all stock. I got 45/175 jets, Screamin' Eagle stage 1 air cleaner kit and Screamin' Eagle 2 pipes off a EVO fitted on the sporty. Not bad power for the first few gears (being a light weight helps) but in 5th it definatly needs a bit more "passing" power. I'm sure the few goodies have to be worth a few more HP but I would be happy with 100-125 HP. Anything I can do with out doing a 1200 kit since those are not cheap by any means
You aren't going to double your horsepower without throwing big, big bucks at it.
If you want to get out of that 50HP range, talk to Dan at NRHS, if you want to keep the cost down go with his standard 1250 kit. That should get you into that 70-75HP range as Charley mentioned above.
When thinking horsepower, look at percentages. Even 5HP right now is about a 10% increase for you.
I think stock HP is about 45, I'm assuming you're making about 50. What about a good aftermarket exhaust - a good performing exhaust, like a 2-1. That might gain you 5-7% over the SE-IIs for $500-600. Easier bolt on, but bang for the buck, I'd suggest the 1250.
Sorry to tell you this but I have dyno tested ( I have my own DnoJet 250i) over 30 diiferent air cleaners and the best ones are only worth about 3-4 extra hp over a stock when used on an 883. An SE is worth about 2-3 in my testing.
Now if you get a 1250 kit to go along with it, the air cleaner is worth more but it still is nowhere close to 10hp. Your SE air cleaner is shown in red.
Received 4,614 Likes
I have an 883, rejetted, k&n knockoff air filter, and an old Honda 750 V4 rated at 82hp (sure it's not that much at rear wheel). Huge difference in performance, yet they weigh pretty close to the same. Haven't raced anyone, but magazine articles place the 750 a little ahead of a 1200 sporty in 0-60 and quarter mile, and a little more on top end. Since my Honda seems really fast compared to the 883, a 1200 would probably be close. See if you can talk a dealer into a 1200 ride, might feel enough difference to make you happy, instead of just thinking numbers. But I know how you feel, thought my 883 would be plenty, but after I got used to it, just not quite satisfied any more.
