Very hard to shift into neutral, 2nd and 3rd
Old 05-02-2012, 02:04 PM
lakegeorgia's Avatar
lakegeorgia
lakegeorgia is offline
Stage IV
Default Very hard to shift into neutral, 2nd and 3rd
Hey all, I am new to hdforums and this is my first post.
I have an 85' Ironhead and I am having a heck of a time shifting from 1st to 2nd and from 2nd to 3rd. It is also extremely tough to get the bike into neutral. The other shifts are smooth and easy it is just these lower gears that are tough. Any ideas of how to resolve the problem? I do not have a clutch adjustment at the handlebar, only on the engine.
regards,
Mark
Old 05-02-2012, 05:12 PM
lakegeorgia
Stage IV
ideas?
Old 05-02-2012, 06:23 PM
notorious's Avatar
notorious
notorious is offline
Pull Clutch Basket and inspect, groves are bad.
Old 05-03-2012, 08:21 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Every Harley I have owned, including a '74, had an adjuster in the cable. The routine is adjust at the clutch, with the cable adjuster slackened right off, then adjust the cable. Sounds as if you could use a service manual and the correct cable!
Old 05-03-2012, 08:31 AM
Zimbob's Avatar
Zimbob
Zimbob is offline
Originally Posted by grbrown
Every Harley I have owned (snip) had an adjuster in the cable. The routine is adjust at the clutch, with the cable adjuster slackened right off, then adjust the cable. Sounds as if you could use a service manual and the correct cable!
Agreed. get a service manual and adjust the clutch, if that don't help, check the primary adjustment. Once you get it right, don't lug it, Sportsters HATE being lugged.
KPMC
04-19-2019 08:47 PM
Jimbo Slice
08-07-2013 07:34 PM
marine_hm@hotmail.com
07-18-2012 08:50 PM
jhowardwilliams
08-31-2011 04:18 PM
WIDERGLIDER
08-30-2011 05:41 PM
Quick Reply: Very hard to shift into neutral, 2nd and 3rd
