What jets would you run?
Old 05-04-2012, 05:14 PM
scaldwellk's Avatar
scaldwellk
scaldwellk is offline
Default What jets would you run?
My bike is a 2003 883. It has a K&N air filter with the back of the stock housing opened up to breath. The exhaust is Basanni Sweepers with short baffles. There is a set of torq cones installed, but not sure if needed. I rejetted to the jet size I was told from the vendor I got the carb kit from. They started to help me then just stopped helping when I asked questions.
What jet size should I be looking at for this bike?
Old 05-04-2012, 05:46 PM
oasis856's Avatar
oasis856
oasis856 is offline
Hello, my jets replaced earlier this week. Rush 2.0, and xlflow added. An old Harley guy suggested that I move up to the next size above stock. New 46 and185. Check the manual, it'll tell the stock size in the 883 - not sure.
I like the way the bike runs, but too little highway time to tell if all is perfect.
Old 05-04-2012, 06:52 PM
scaldwellk's Avatar
scaldwellk
I think stock is 160 and 42?
Old 05-05-2012, 07:35 PM
jag1886's Avatar
jag1886
jag1886 is offline
Move up one size 45 slow and 165-170 main.
Old 05-07-2012, 12:26 PM
iceman336's Avatar
iceman336
iceman336 is offline
Old 05-07-2012, 12:45 PM
cHarley's Avatar
cHarley
cHarley is offline
Originally Posted by iceman336
45/180
For a 1200 yes, but that's a bit big for a 883.
All bikes are a bit different, but I'd start by just going up 1 size (to a #45?) pilot jet and a 170 main jet.
Note: 1 size on the pilot is from a 42 to a 45.
Old 05-07-2012, 05:28 PM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
I have a 2000 883 that has SE A/C and SEII pipes on it. It's jetted at a 45 and 170. Recently had it on a WOT dyno run, and the 170 is a little much, but doesn't really play into every day riding. It runs perfect and in tune otherwise. Cruising MPGs are good. Mixture screw is appx. 1 1/8 turns.
Old 05-07-2012, 05:54 PM
scaldwellk's Avatar
scaldwellk
Thanks for all the info. I am now going to have to play around with this carb.
Mr_Didwork
08-14-2014 05:53 PM
JimA
08-07-2013 11:22 AM
maxi426
Exhaust System Topics
06-02-2012 11:24 PM
detailshop
08-08-2007 07:35 PM
mattb43
11-06-2006 03:14 PM
Quick Reply: What jets would you run?
