2012 Forty Eight bobber, start to finish
170 or larger you say? Hmmmm...wonder what my Nightster will allow for. I thought the stock width was absolute max on these. Did the chop open it up for more room or?
The only thing I'm not really digging is the skronny struts. I'd have gone Biltwell or DK Custom on those. Also not a fan of the super apes, but that's completely rider preference.
Thanks a lot, now my gears are turning on new rear meat.
The bike looks awesome! I really like the look of the rear fender. Did you just cut it and then bring it to a paint shop to have it touched up, or did you have it completely repainted? did you have to do any special mods to keep the rear lights in that location, like bring back the mounting hole? Or is it in the exact spot as the stock location? For some reason it seems like they are pushed back from stock in the photo. Could be just because of the fender.
Thanks,
-Chris
Thanks,
-Chris
As for the rear tire, im sure the chop would help it fit a bigger tire because all the reflector mounts and such are not there anymore. Which leaves the next closest point of rubbing at the belt. I have about 1/2" to a 1" between the tire and the belt so id say a 180 would fit no problem. Good luck
Thanks,
-Chris
Thanks,
-Chris
Only 1 of the mounting holes is still on the frame because i cut a good 4-5" out of the frame. As for the signals i made my own mounts for them out of tube then used longer bolts and the factoy hole closest to the front of the bike to mount the signals and the fender.
