My Sportster is leaking gas from the carb!
Old 05-10-2012, 09:34 PM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,643 Likes on 1,133 Posts
I think your screws are cadmium plated steel, not brass. Most carbs have cad plated parts that look gold (brass) when new, your picture looks like cad plated screws, not brass.
Your mechanic just does not know how to properly install/remove Phillips head screws, they are difficult. Phillips heads are designed for max torque on installation, but are problematic on removal.
John
Old 05-10-2012, 09:41 PM
Duckslayer12's Avatar
Duckslayer12
Duckslayer12 is offline
6th Gear
Yea I think you are right on what type of steel they are. I noticed they are silver under the coating. I'm suprised he didn't see the diaphragm problem since he works on carbs a lot. I didn't notice any screw heads messed up until I started working on it. I didn't think they would be so dang tight! Is there a secret to taking them out? I applied a lot of pressure but still stripped the head some how. I did have the right philips tip to so it wasn't too small or big.
Old 05-10-2012, 09:56 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
I work on carbs all of the time. I use an impact driver with a phillips bit on the end, I tap it lightly to break the screws loose. As the cover screws may be a brass color, they are not brass but the heads do strip easily. My best guess is that you will only need an accelerator pump diaphram, but cleaning out the whole carb and replacing all of the rubber pieces won't hurt a bit.
If the head is already stripped, get a cutting wheel on a dremel and cut a slot in the head and use the impact with a straight blade screwdriver bit. Then replace the screw with a new one.
Old 05-11-2012, 06:33 AM
Duckslayer12
6th Gear
Thanks for all the help guys!
Old 05-11-2012, 07:33 AM
Duckslayer12
6th Gear
Got the screws out and it looks like I need a new accelerator pump diaphram. There is a nice size rip in it which makes sense as to why I have so much gas leaking. Hopefully the local harley dealer will have some replacement parts for me. This will get me by until I can do the rebuild kit. Thanks for all the help everyone! This forum is awesome!
Old 05-11-2012, 08:56 AM
ctrlaltdefeat's Avatar
ctrlaltdefeat
ctrlaltdefeat is offline
Stage I
If you don't get the parts covered by the local Harley dealer or discounted at least there is a website that strictly sells Harley parts and great prices as well. Here is the site:
http://www.jpcycles.com/harley-parts...FQlN4Aodc1QJEQ
Old 05-11-2012, 08:31 PM
Duckslayer12
6th Gear
Gpsjr10, where do you get replacement screws? I looked at Lowes and they didn't have much of a selection and I don't know the exact size. I need screws for the accelerator pump cover.
Old 05-11-2012, 11:25 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
well, I have a box full of old Mikuni and Kei-Hin carbs, so I just steal parts from them. I am pretty sure they are metric screws. I can check when I get to the shop tomorrow. If you go to the dealer and get a new pump diaphram, they may have some laying around. If you can't find them, PM me and I will send some to you.
Old 05-12-2012, 08:03 PM
Duckslayer12
6th Gear
That would be awesome if you can help me out! Even if you knew the screw/thread size so I can order some would be great. I can't seem to figure out how to just the PM system?
Old 05-12-2012, 08:28 PM
TheGarbon's Avatar
TheGarbon
TheGarbon is offline
I just rejetted my carb and had to replace a screw. Took it to Ace Hardware and they got me a new one for about a dime or so.
Quick Reply: My Sportster is leaking gas from the carb!
