My Sportster is leaking gas from the carb!
me too
have a leaking carb also, just not the same side. At first i thought i would have to rebuild my carb as well, then after further examination (and the same problem with the screws) I thought I would just keep trouble shooting. I found that I had a really rotten fuel line (so i replaced) and then i still had a little bit of leaking a lot less than before so i took it all back apart. All i can find leaking now is this little black plastic inlet. in photo1 you can see it is a little wet from gas. I wipe it down and let it idle just the tiniest amount leaks out looks like there is a hairline crack.
1. what is thing called? in photo 5 from my book its called "the body" so i know the book is refering to the carb its self not the inlet.
2. in photo 3 and 4 im showing that some one has done mods to this bike that i dont understand. is it ok?
i have an 89 sporster deluxe that should have another cable from the throtle to regulate i guess. instead i have a screw with a spring. WTF?
Home Depot and Lowes both have the screws you need. Check the specialty drawers in the fastener isle. Ask for help, they'll show you how to check the thread size and help you find it. They are tiny, can't be much. I'd never pulled a carb apart, was able to rebuild mine. check out youtube. There's tons of video instructions so you can see them do it. Once you've watched a couple You'll be saying... That's it?
Here's a good one to get start with...
