Dead sporty.....need some advice
But go ahead, jump your bike with it's little dead battery with a 100+ amp source. No skin off my back.
BTW, you do know that the regulator in the Sporty sinks to ground, right?
Oh, and that dead battery on the bike, it's a BIG low resistance catch can. That's why when you throw a variable current (AMP) charger on a dead battery, it pegs the Amp meter on the charger.
Yea, I know all about Ohm's law and quite a bit more electrically, I'm an electrical engineer.
I see more than one person missed a few classes in the high school.
Why don't you do a little test.
Take a 12 V, 60 W light bulb and connect it to a running truck - so called 100 A source. Take a note of current generated by light bulb. It will be just over 4 A.
Now take the same bulb and connect it to your running Sporty - so called 30 A source. Compare amperage readings, they will be practically same.
Because current is determined by bulb, not source.
There can be a small difference if the charging systems are not producing exactly same voltage. This is determined by Ohm's Law.
A little more education:
Metric system units that are named after a scientist are uppercase.
V - volt - named after Alessandro Volta
A - amper - named after André-Marie Ampère
Lowercase v denotes speed in formulas, in case if you are interested.
A 0.54 Amp (60 watt) lightbulb in your house does not blow up because it is fed by a 20 Amp circuit breaker. The lamp is "pulling" power, it's not the breaker that is pushing in the bulb.
I understand electrical engineers may have hard time understanding this, but hopefully other people will benefit from my postings.
Ohm's Law, again. Breaker is a passive element, it does not affect the current. 60 W 12 V lightbulb will draw over 4 A. 0.54 A current is determined by resistance of filament, which is much higher for a 120 V source.
Received 20,876 Likes
Yes, and since all electrical loads are connected in parallel, in this case the dead battery is a load, too, the current generated by dead battery affects only the battery itself - it does not mean any other load on bike (ECM, fuel pump, etc) will get higher current than usual.
I guess you've never seen a little (12 amp-hour) dead battery explode when it's hit with 100+ amps.
And while we're at it, you said;
"Lowercase v denotes speed in formulas, in case if you are interested."
No, it stands for velocity, speed and velocity are not the same thing.
Alright, you've got me here. I didn't double-check terms, and since English is fifth language for me I got this one wrong.
