Future of my Iron - springer front end?
The OP in that link(HoldFast) actually installed a LedSled springer on his bike. I think he ended up needing a new caliper as well. Perhaps you could PM to ask about his total cost.
Here is the info on the Zero Engineering springer, which is currently out of stock (not that I'm ready to buy, lol)
So this is for sure a bolt on part and I wouldn't have to do any modifications? I need this to be easy!
It's more expensive than the Led Sled, but I trust mreed and what he says on the matter.
To me, since I'm such a n00b, simply a springer was old school. So I REALLY appreciate the advice of you guys who know the difference between your ******* and your elbow. Especially from those of you have ridden on them. This would be my first experience.
A guy at work was saying it would be like riding a jack hammer. lulz
Availability: Out of stock
$1,545.00
Quick Overview
* Glossy Black
* Standard 1" Steering Stem
* 30" length
* 17.5" from neck bottom to hub
* Considered to be 2" under standard length
* 3/4" axle
* Best suited for custom application
$1,545.00
Quick Overview
* Glossy Black
* 30" length
* 3/4" axle
The Zero Engineering® Springer Fork- an updated, ruggedized "In-Line" type based on 1930's-1940's Big Twins with ~38 degrees frame necks. Improvements include needle bearings, reinforced joints, an adjustable bushing for tension, and mounting for a disc brake.
If your front suspension is stock you probably wouldn't notice the difference lol. I upgraded my shocks to Ohlins sprung for my weight but it made little difference. I still come 6" off the seat at hiway speeds when I hit a big bump. I've personally decided to live with it and go with a springer. Though in my case I want an actual HD springer from the 40s. Worst handling bike I've ever had but it's fun and beautiful so I'm learning the trade offs.
Don't believe that one is a bolt on. With the 04 and up rubber mount Sportsters you would need to springer to have an offset neck. If not the rear leg will contact your frame which will limit your turning radius. The offset neck allows the rear legs of the springerto clear the frame and not make contact.
Yup, they make them for modern Sporties. Their pipes for '03 and under bikes are a bit cheaper, though. I assume because they have to add 02 sensor bungs or something for us with EFI.
