Brand Motor Oil
Brand Motor Oil
New to forum. I recently purchased a 07 sportster 1200 custom. It has 11,000 miles. This is my first Harley. It was not purchased at a Harley Dealership. I do not know what brand of oil is in bike now. I was told that bike was completely serviced. I would feel better if I changed the oil, so I would know when it was done. What brand oil is the best to use. I would assume HD oil is prefered. Should I use syn oil or conventional motorcycle oil. Just curious what everybody else is using in their sportster. Thanks for any info.
Welcome to the forum. If you do a search you will find 18,000 threads here on oil.
Personally I use Amsoil 20W50 synthetic in the engine, and Harley Formula+ in the primary. I like Mobile 1 V-Twin as well, but where I live I can get the Amsoil cheaper.
Any oil with the correct weight will be fine, these aren't Ferrari engines.
I use Mobil 1 20w50 VTwin myself. The conventional HD branded stuff is fine to use, a lot of people here use it. Quite a few people (myself included) have tried Syn3 and dislike it for one reason or another. Amsoil is another fantastic product and has a strong following.
Also, don't try to save a buck or two with a filter. Genuine HD is the only way to go with these. They're all of $6-$8 in your choice of black or chrome at the dealer. If you can obtain an owners manual or service manual it will show you how to change the oil. There is no drain plug!
I usually buy three quarts. Fill the filter halfway, dump the remainder along with another full quart into the tank. Start it, wait for the red oil light to go out, shut it off. Adjust as needed from there, roughly halfway between the full and add marks on the stick, usually a little on the low side to prevent high rpm puking.
if you want to read more there is a whole section here for oil related topics.
I use Mobil 1, I like synthetic and its the easiest for me to find
https://www.hdforums.com/forum/oil-a...ted-topics-30/
Good thread here on Sportster oil filters:
http://xlforum.net/vbportal/forums/s...d.php?t=736235
