DK Customs Thunder Torque Inserts Review
#131
Received 3,940 Likes
The TTI's work well with both the stock V&H baffles AND the "quiet baffles". You will definitely pick up some low and mid range power...enough to feel!
#132
#133
The W158's if running no baffles.
The vid below gives you an idea of what it sounds like on the road, with no baffles and the W158 Thunder Torque Inserts
#134
#135
You would not even have to do any auto tune sessions, let alone change your base map.
Auto-tune will not hurt, it will help enough to show up on a dyno chart, probably not enough to feel it seat of the pants.
The reason why these give more power, regardless of the tune, is that they are increasing the exhaust gas velocity, resulting in a "cleaner" more productive charge on each combustion stroke.
Doing an auto tune, while not necessary, will help, because it will now see the non-corrupted by reversion charge in the cylinder and make some small adjustments to take advantage of it.
#136
I realize this is an older thread, but I will be purchasing a set of these tomorrow. I have the V&H BSS, on a 14' 103 motor, and I'm wondering if I should leave the stock baffles in, and just bore the set screw hole, or remove the baffle all together.Also, in reading, I think the TTI's are supposed to be located about 2 inches from the end of the pipe. I have the black BSS's, so my heat shields have a chrome cap on the end, putting the baffle hole about 4 inches back from end of pipe. Does this mean I should drill a new hole and not use the factory baffle hole?
Which size TTi is recommended, and I assume I need to completely remove pipes to install, so I should probably order new exhaust gaskets also.
Thank you
Regards
Rollcage
Thank you
Regards
Rollcage
#137
BUMP TO A OLDER THREAD, ordered the tank lift last week, VERY IMPRESSED W THE QUALITY I mean, the hardware is heavy duty fellas, so yesterday I called, there were super helpful I have the 158's coming in the wave version, to go on my rocker c, vance and hines big radius dual, report back on how they perform, no offense to big city, but for the money, I just couldn't find any real happy customers? tti however, I haven't heard any complaints, so that's why I chose how I did, excited to get them here, have baffle's removed already to rock...lo,
DK Custom (02-12-2018)
#140
