1988 sportster shooting flames problem
my 88 sportster has a a 98 softail carb and i can't seem to get it running right it carries on and shoots flames out the exhaust. there is a voe on it that has something to do with vapor and on the top of the carb are 2 holes the same as the 1 that the voe is hosed too so i just plugged them i am not sure what is wrong but any info will help a lot
Some would love an afterburner exhaust! The bad *** biker Leonard Smalls had this feature in the movie Raising Arizona. Now you can really torch tailgaters with a twist of the throttle. Sorry, couldn't resist - just kidding, man.
Obviously you're igniting unburned fuel in the exhaust. A starting point is to read your plugs to see if you're too lean or rich, then troubleshoot the carb from there. Other factors may be exhaust joint air leaks that promote the famous decel pop or ignition timing. Hard to say without more data, but I suspect the carb may be a mismatch.
Cheers, RR
Cheers, RR
Cheers, RR
Cheers, RR
how exactly am i supposed to read the plug
no never ran right with this carb but the original carb had this same exact issue thats why i replaced it
