Neutral light/switch on 07 Sporty.
Hi there
I've got a buddy with an 07 (50th) Anniversary Sportster which yesterday decided not to show the neutral light in the led module. Made sure the gear linkage was adjusted correctly although nothing has changed since the bike was bought new.
Done a bit of research and apparently the neutral light switch is the culprit and a common problem. It sits in behind the front drive belt pulley. Anyone replaced the switch? Easy job?
Also and this is also a question I could not answer for him. He reckons he's always been able to start the bike with ignition on-> switch set to run->press the starter while the bike was in neutral. Now the only way to start the bike with it in neutral is with the clutch lever pulled in??? Something to do with the neutral light not working?
Cheers
Cheers
Are you sure it is the switch and not a wire!? Follow the wire (tan) and make sure it is connected in the 2 spots! should run to your harness and split to go up to the speedo cluster. To make sure the switch is good, get a good ground, be sure it is in neutral and use a light or what not with the wire coming out of the housing to see if there is power.
Hi there
How did you lock the front sprocket in order to remove and replace the nut?
Also if anyone else is reading this post. The neutral switch has one (tan) wire going to the switch. It's difficult to get to because of its closeness to the transmission sprocket BUT (silly question, I know) can the wire be removed from the switch to test to see if the switch is faulty or if the problem is between the wire and the neutral light? I can't tell how the wire is removed? In other words does it pull straight off or "off" to the side? And can it be reconnected. There's not alot of space there
EDIT: managed to "fiddle" the lead of the switch, grounded it and the neutral lights up! So. it's the switch. Anyone tell me what the exact size is of the mother of a nut holding the sprocket on?
Cheers
