serious problem - Backfire Sportster
Old 09-24-2012, 12:00 PM
mikelangelo's Avatar
mikelangelo
mikelangelo is offline
Stage I
Exclamation serious problem - Backfire Sportster
I bought at auction a SPORTSTER NIGHTSTER 2008 and was with broken engine without ECU. I changed many parts to the engine (piston, rings, cylinders, lubricators, camshafts, etc.) but could not get rods alone, so I bought on ebay a crankshaft of a 2005 Sportster and a ECU another ECU sportster 2008. (The Number ECU 32140-08)
When the engine was running the sound is good, but had Very much backfiring. When I looked at the spark plugs, the front had extremely poor and the back very rich. (definitely the engine is off point.)
I do not know if the problem is the ECU or crankshaft, I read in another post that the ECU has to be according to the VIN and maybe that's the problem?
I also thought that might be the crankshaft, but when I compared the pieces are exactly alike. In the part number gives the crankshaft Harley 2005 (23905-04) and the crankshaft of 2008 (23905-04A).
How Can I solution this problem?
I also thought that maybe the crank sensor would be replaced by 2005, because I installed a crankshaft 2005.
Sensor 2008 (32707-01C)
Sensor 2005 (32804-04A)
I need a help to solve this problem.
Old 09-24-2012, 02:39 PM
J.R. White's Avatar
J.R. White
J.R. White is offline
Probably better to post this in the tech side of the forum.
milan707
11-06-2018 09:43 PM
Sledge
Sportster Parts
06-05-2011 12:23 PM
FotoDeville
05-06-2011 01:08 PM
rbdoherty
10-23-2009 11:02 AM
balley
Motorcycles For Sale
10-13-2007 03:11 PM
Quick Reply: serious problem - Backfire Sportster
