oil leak from rocker covers
07 nightster with about 6700 miles on it.
I think this is a decently common issue with these motors, but the rocker cover gasket appears to have failed.
Either that or the one allen key bolt is loose and out of torque? I have a PDF service manual which is a b*tch to navigate and I couldn't find the torque specs on those bolts(part 1 in the attached screenshot), anyone know what it is?
It looks fairly simple to replace the gaskets (# 4 and 5 in the attached), am I over looking anything if that is indeed the issue?
Good news mine just started leaking from same spot on rear.
I picked up all 3 gaskets at the dealer for $15.
I'm just going to do the rear cover as that's the one that's
Leaking. As far as the front my logic is if it ain't broke don't
Fix it. U can google the torque specs or find them here
Not good news it's leaking , it's the 15 bux
It's something to do with the new rocker boxes. The pre-rubbermounts have leaks too (mine did on both, thanks to paper OEM gaskets), however they are a one time fix pretty much. The rubbermount two-piece rockers must be a different manufacturing process or supplier, or both, and have a much harder time staying sealed.
Those rocker box gaskets can be a pain to keep in place when installing the covers, they twist and shift out of place easily. Make sure the gasket mating surfaces are clean and smooth and be patient making sure they stay in place while you torque them down. I think the torque is something like 17 inch lbs.on the top cover. (Allen head bolts)
