stock 48 rear tire
Old 10-14-2012, 11:38 AM
groverhd's Avatar
groverhd
groverhd is offline
Default stock 48 rear tire
Has anybody changed the rear tire size to match the front tire on the 48? If so can it be done easy without any modification? i want a bigger rear tire but don't want to change wheel. at least have the same as the front
Old 10-14-2012, 12:56 PM
cpracing519's Avatar
cpracing519
cpracing519 is offline
the rear tire on the 48 is wider than the front. the rear is a 150 and the front is a 130.
Old 10-14-2012, 02:22 PM
blacklander48's Avatar
blacklander48
blacklander48 is offline
Im looking at this 2 tires and wondering if it could fit? Pretty sure the front will fit. But unsure of the rear.
Cobra AV71(front)
Load Spd: 74H
Width: 136mm
Cobra AV72(rear)
180/70R16
77H
182mm
or
Cobra AV72
170/70R16
75H
170mm
any advice from you guys?
Old 10-14-2012, 04:52 PM
groverhd's Avatar
groverhd
groverhd is offline
I want to change mine to the white walls but i want them as fat as stock wheels will allow. my rear is 150/80 but it seems not as wide as the front 130/90. i am not a tire guy obviously ....thanks for any schooling that yall can do for me
Old 10-14-2012, 05:48 PM
cpracing519
I know someone on here put a 180 Avon on the rear. It was a tight fit, but works. It looked real close to the belt though.
Old 10-14-2012, 05:51 PM
groverhd's Avatar
groverhd
groverhd is offline
Can you think of any cons with going that 180?
Old 10-18-2012, 06:09 PM
c0jones's Avatar
c0jones
c0jones is offline
A 180 would require a wider rim.
The Softail Deluxe uses MU85B16 for the rear.
It's a 144 & about a quarter inch taller than your 150.
Old 10-19-2012, 06:37 AM
Sticky4's Avatar
Sticky4
Sticky4 is offline
I'm running a 170/70 Shinko WW. No issues. But I did knock out my edge fender LED light on the first ride!
Old 10-19-2012, 05:38 PM
IR0N883's Avatar
IR0N883
IR0N883 is offline
are you running the same exact size (170/70) front and back?
Old 10-24-2012, 02:43 PM
groverhd's Avatar
groverhd
groverhd is offline
That's a great looking bike! what size is your front tire?
Quick Reply: stock 48 rear tire
