Tire Pressures
Also, for some more good info, the tire pressure listed on the sidewall of the tire is the MAXIMUM cold inflation pressure for that tire.
The only time you fill it that high is if you are loading the tire to its maximum capacity (you can get close 2-up with luggage on the rear tire). The tire is not meant to be run that inflated all the time.
