Post your Dyno results here.
  #91
Old 03-13-2014, 03:50 PM
rocketmangb's Avatar
rocketmangb
rocketmangb is offline
Call Hammer Performance in Idaho
  #92
Old 03-14-2014, 03:19 PM
Imus's Avatar
Imus
Imus is offline
Thanks Rocketman! I wrote to them and Aaron sent me an estimate. He said I need a new 1250 kit with different pistons and Crush 600 cams and new 1200 heads with Crush head work and ported throttle body roller rockers bigger air cleaner and new oil pump gear and new gaskets and new pushrods. Came to 3473.89 with the discount. It saved me some money because I already have the Powervision and Patriot and clutch upgrade those add up to about a grand saved.I'm thinking about it.
  #93
Old 03-14-2014, 04:25 PM
rocketmangb
My '06 is currently under the knife !
1250 with 10.9 compression
Sledge Heads with 1.94x1.61 valves
600 Cams
S&S Roller Rockers
Jims Hydrosolid lifters
Smith Bros pushrods
Hammer Billet Manifold
HSR45 Mikuni
Hurricane Flow air cleaner
Patriot Pipe
TC88A Ignition
Alto Carbonite Clutch
  #94
Old 03-14-2014, 05:49 PM
Imus's Avatar
Imus
Imus is offline
Holy crap your gonna live up to your name Rocketman!
Here's what I want he said this is from his shop mule efi 883 with the crush 1250 setup:
  #95
Old 04-05-2014, 02:58 PM
markdt's Avatar
markdt
markdt is offline
Default dyno
Originally Posted by cHarley
If they had, it would likely have also shown higher than normal numbers. The fact that the chart lacks all of the typical dyno setting information, like SAE vs STD, temperature, humidity, correction factor, smoothing, etc, make the resulting numbers very questionable.
It's real easy for a dyno operator to "blow smoke" up an owners *** just to put a smile on their face by giving them artificially high numbers.
Sorry, but there is no way in hell a stage 1 1200 pulled those numbers without the dyno being fudged. 87 ft/lbs of torque just ain't happening on a stage 1 1200.
Agree, mine is a carbed S&S , ported head 1200, 9:1 comp Keith black pistons with Andrew n2's does 81hp and 74tq @ 6500rpm. This is considered a stage 2.5 by Harley standards. I suppose I could pick up another 5 with 10:1 pistons and n4's , but it would hardly be noticeable in everyday riding at 3000 rpm
  #96
Old 04-06-2014, 12:35 AM
rocketmangb
Mark
Those numbers are within reason !
  #97
Old 04-09-2014, 10:20 PM
ClodeV's Avatar
ClodeV
ClodeV is offline
I just got my base line numbers on my 2000 XL1200 sporty. This is prior to any engine work that i will do in the fall most likely. HP 58.7 Tor 61.2
  #98
Old 04-09-2014, 11:22 PM
Bowhunter8607's Avatar
Bowhunter8607
Bowhunter8607 is offline
Pretty good for stock numbers! What do you plan on doing to it in the fall?
  #99
Old 04-20-2014, 10:31 AM
Madnss's Avatar
Madnss
Madnss is online now
Received 1,051 Likes on 568 Posts
1992 XL883
HAMMER PERFORMANCE Bolt-on 1250 Kit with 30 Degree Reverse Dome Pistons
HAMMER PERFORMANCE Sledge Head Porting Service on XB heads
HAMMER PERFORMANCE CRUSH 600 Cams
HAMMER PERFORMANCE Billet Intake Manifold
Mikuni HSR45 Carburetor
Patriot Defender Exhaust System
Daytona twin tec ignition
  #100
Old 05-15-2014, 11:05 PM
Bowhunter8607
Got the Dyno results for my 88 ci Sportster! Keep in mind this is at 7200 ft. elevation. She's pushing 97.51 max power and 94.40 max torque! Couldn't quite break 100 hp at this elevation but im stoked either way!
Attached Thumbnails Post your Dyno results here.-20140515_215012.jpg   Post your Dyno results here.-20140515_214855.jpg   Post your Dyno results here.-20140515_214835.jpg
Quick Reply: Post your Dyno results here.
