Post your Dyno results here.
Old 01-03-2016, 11:33 AM
rocketmangb's Avatar
rocketmangb
rocketmangb is offline
Well lets see here
Bikes a Rigid mount
S&S carb
Dynatek ignition
Almost has to be an 88 incher by the TQ numbers
XB heads from Hammer with Crush porting and 10 or 10.5 compression
Hammer 560 cams
Your turn !
  #122
Old 01-03-2016, 11:49 AM
marcodarq's Avatar
marcodarq
marcodarq is offline
so far Rocketman is in the lead with the positive ID on=
1. S&S Carb w/TunderJett
2. Ignition, though not Dynatek
3.89 inch S&S hot set up strokerflywheels/ 3 5/8 bore
cams heads and compression is there, just not Hammer products, other things that i've liked to use, before Hammer was even out there.
other guesses?
m
  #123
Old 01-03-2016, 11:51 AM
marcodarq's Avatar
marcodarq
ps, bike is not a Rigid, Running Progressive stuff in the back and my own blend up front!
m
  #124
Old 01-03-2016, 01:26 PM
rocketmangb
Rigid Mount Frame bike
03 or earlier
  #125
Old 01-03-2016, 01:28 PM
rocketmangb
NRHS or S&S Superstock heads
Andrews N8'S or maybe the Red Shift 643's
  #126
Old 01-03-2016, 09:29 PM
marcodarq's Avatar
marcodarq
stcok H-D head castings, ported and worked by my machinist. 93 model year, not rigid, stock(chrome)swingarm, Progressive Shocks and older design, cant remember the number off the top of my head, but they are adjustable for spring pre-load and re-bound.
cams are very off the beaten path, but not andrews or redshift.
m
  #127
Old 01-04-2016, 09:50 AM
rocketmangb
Leinweber or Sifton ?
  #128
Old 01-04-2016, 10:28 PM
marcodarq's Avatar
marcodarq
Believe it or not, i'm running the old Edlebrock cams that they made to match their heads back in the days when they were trying to make H-D stuff. Most of the other crap they made was crap, but i do like the cams and they have worked well with a couple of other head set ups I've used in the past.
  #129
Old 03-09-2016, 05:41 PM
drinktothat421's Avatar
drinktothat421
drinktothat421 is offline
just got a dyno run today. will be going back to a full tune.
  #130
Old 03-10-2016, 12:41 PM
Bonneville Racer's Avatar
Bonneville Racer
Bonneville Racer is offline
drinktothat,
are you running drag pipes as that is showing some terrible reversion typical of drags.
Quick Reply: Post your Dyno results here.
