Clearance issues
Not sure what year your bike is, but I have a 2002, running it with drag bars, 4 1/2" pull back risers, and speedo relocated to the tank bolt. No issue with the speedo at all. I did have to slide the controls out a bit as the switch housings would barely touch the tank at full turn. My signals are relocated to the forks, and I've removed the mirrors. Couldn't see past my shoulders with the drag bars, and I always turn my head to look when switching lanes anyways. Not going to trust my life with a little ity bity piece of reflective glass.
here ya go: I have 28.25 in drag bars with 4.5" pull back, no tank lift, mirrors flipped, but I used a little different set up than directly mounting to the tank mount bolt as you can see. But zero rubbing.
fully cranked:
closer view of speedo relocate (still need to touch up that white):
overall view from back:
fully cranked:
