First oil change, newb question
Hey guys,i did my first oil change since owning my bike. Fairly easy job but here is my question. I used mobile 1 20w-50 and a fram oil filter ( closest hd dealer was about 2 hrs away) I read these filters aren't quite as good as hd and must be changed sooner, so with this setup I how long before my next oil change?
The fram fillter number is the only one I had written down, and didn't want to use fram either.. so I asked the guy at the parts counter what the K&N equivalent was and used that. The K&N also has a nut on the top of the filter so it's easy to get off. If I were you, I'd change it now. Especially if this is a new bike, you're going to get more than normal metal shavings out of your 1k and maybe 5k oil changes.. just my opinion.
Received 2,189 Likes
You can pick up a Chrome or Black K&N 170 filter on Amazon for less than $15 shipped.
I don't know what you payed for the fram but K&N is just a better unit IMO.
http://www.amazon.com/KN-170-Harley-Davidson-Performance-Filter/dp/B000E28C8G/ref=sr_1_3?ie=UTF8&qid=1362672466&sr=8-3&keywords=k%26n+170
Makes removal real easy.
Hope that was mobile 1 20/50 VTwin oil.
All of this is available on amazon.com.
No need to visit a dealer.
V-Twin oil is specifically made for motorcycles with a single oil sump (supply), where the same oil lubes the motor, primary and tranny. V-Twin oil does not contain any friction modifiers because they are bad news for the clutch. But friction modifiers like molybdenum, are a good thing to have in the motor as it prevents cold start wear and tear before the oil pump gets the oil circulating.
