Rear Axel tourqe
Old 04-21-2013, 01:06 PM
cpudoc's Avatar
cpudoc
cpudoc is offline
Default Rear Axel tourqe
Guys,
My buddy is bringing his 05 883 to remove the rear wheel for painting. I can not find the specs for the rear axel nut any ideas?
My Roadking says 15-20 ft pounds but Thats a touring bike
Old 04-21-2013, 01:22 PM
iwantmybeerbackplease's Avatar
iwantmybeerbackplease is offline
Rear axle nut torque according to my '08 service manual is 95-105 ft-lbs. Where did you get 15-20 ft-lbs?!? That couldn't be for an axle nut. BTW, front axle nut is to be torqued to 60-65 ft-lbs.
-Beer
Old 04-21-2013, 01:25 PM
cpudoc's Avatar
cpudoc
cpudoc is offline
Thanks,
You are right The Roadking is using a multiplier because of the way it needs to be tightened
Old 04-21-2013, 03:27 PM
1200Cdriver's Avatar
1200Cdriver
1200Cdriver is offline
CP, there is a difference between the solid axle like on my 2007 1200c and the hollow axle of 2008. The solid one torques to about 75 ft lbs not to exceed 78. If you exceed 78 it will crush the bearings and the wheel will not turn. The hollow axle will accept the 95 to 105 ft lbs. cHarley know which is which.
Attached Thumbnails Rear Axel tourqe-xl-2005_harley_davidson_sportster_xl883l-left.jpg
Old 04-21-2013, 04:06 PM
chappy99's Avatar
chappy99
chappy99 is offline
Rear axle 72 to 78 ft lbs
rear sprocket 55 to 66 ft lbs
markaria
Shovelhead
06-03-2015 05:51 AM
Red Dragons
05-19-2014 09:10 PM
glcash
12-16-2012 07:03 AM
klinker24
09-17-2010 07:54 AM
robertj74
04-10-2008 05:05 PM
Quick Reply: Rear Axel tourqe
