Hi all I have a 2006 1200low the bike will idle and while out of gear I can rev it up the problem is when I put it in gear and go to take off it dies as if its not getting gas.Idling is fine.I have cleaned the bowl and the jets.I have watched when I twisted the throtlle and gas is going into the carb.any help? thank you
Have you checked your slide/diaphragm for proper operation? Also, you may have put the needle jet in upside down, that has come up a couple times recently.
Hi John,the slide seems to be working fine we did not take the neddle jet out we only took the main jet out and cleaned it,sorry I miss spoke.It seems to throttle fine in neutral but when i hold the clutch put it in gear and go to take off is when it dies thank you
