2005 sportster speedometer
Old 05-28-2013, 07:41 PM
oldmotors's Avatar
oldmotors
oldmotors is offline
Stage IV
Default 2005 sportster speedometer
Hi I'm new to the site I have a 2005 Sportster the speedometer doesn't work no light no mile per hour no mileage any ideas
Old 05-28-2013, 07:56 PM
JeepnHD's Avatar
JeepnHD
JeepnHD is offline
1.fuse
2.check the harness
Old 05-28-2013, 08:36 PM
oldmotors's Avatar
oldmotors
Stage IV
thanks I'll check where are the fuses located and does anyone have a wiring diagram I just got the bike and the previous owner said he checked all the fuses but I would like to double check
Old 05-28-2013, 08:50 PM
ib5150's Avatar
ib5150
ib5150 is offline
You might call your local HD Dealership and ask about a Manuel for the bike, they come in extremely useful for an array of repairs, if they don't have it check ebay..
Old 05-29-2013, 05:43 AM
fourhour's Avatar
fourhour
fourhour is offline
It's the middle fuse next to the starter relay. I've been having issues with my Father's 2005 883 as well. I have a short somewhere either in the speedometer or the wires that come from it to the indicator lights on the bars.
Old 05-29-2013, 09:29 AM
oldmotors's Avatar
oldmotors
Stage IV
I have also noticed that the tach is somtimes erratic are they both on the same plug or harness
Old 05-29-2013, 11:15 AM
fourhour's Avatar
fourhour
fourhour is offline
Should've added that the starter button was out too!
Old 05-29-2013, 02:13 PM
oldmotors's Avatar
oldmotors
Stage IV
Nothing else is wrong just the speedo no light no mph and no odometer
Old 05-29-2013, 03:20 PM
fourhour's Avatar
fourhour
fourhour is offline
The speedo uses the same fuse as the starter button, so eliminate a fuse error if the bike turns over. I opened up the speedo and disconnected the wires the other day after tracing the short to there. I then ran out of time and am contemplating a little journey later on to trace it further. The speedo powers up the neutral and oil lights as well as the ground points for the five indicator lights on the lower handlebar.
So now I'm faced with a short in the speedo or beyond that to the five indicators.
We are expecting severe weather this evening but I may attempt a road trip.
Good luck with yours.
Fri, 5/31: Found out today the bold info above is wrong. The wires come from the same harness, but branch off before the speedo. So now I have start, ignition and all lights. Just no speedometer/odometer. I'm going to try to disconnect the ignition wire that goes into the speedo and see what happens. Could've sold it today if it wasn't for that little problem.
Last edited by fourhour; 05-31-2013 at 03:43 PM. Reason: Better educated...........
Old 03-19-2017, 03:01 PM
Ckelliher's Avatar
Ckelliher
Ckelliher is offline
Stage I
I'm have the same problem with my sportster. Only difference is that my speedometer lights up and works fine when I use my back break. Any help would be appreciated.
TR450
05-20-2015 01:13 AM
tang3662
10-09-2012 08:59 AM
KCFLHRC
Motorcycles For Sale
07-16-2010 03:07 PM
kobark1
11-01-2009 01:55 AM
Jimmym
Electrical/Lighting/Alarm
08-25-2009 03:28 AM
Quick Reply: 2005 sportster speedometer
