90 inch Sportster?
Old 05-30-2013, 11:42 AM
motohaid's Avatar
motohaid
motohaid is offline
Default 90 inch Sportster?
I hear a lot about 883 to 1200 conversions but has anyone ever tried one of these on their 1200?
1474cc 90 inch Monster big bore kit, for Harley Davidson evolution Sportster and Buell 1986 and later
This top end set will create more horsepower and engine life due to their cooler running temperature
This is the best high performance top end set available
Cylinder and piston kits come complete with one piece, all aerospace grade aluminum nickel-silicon carbide plated bore cylinders, complete forged piston kit and cometic head and base gasket kit!
3 7⁄8 inch bore millennium technologies Revolution cylinders
10.5:1 forged pistons, pins, clips, rings head and base gaskets
CASE BORING REQUIRED
Old 05-30-2013, 11:59 AM
Madnss's Avatar
Madnss
Madnss is offline
Received 1,050 Likes on 568 Posts
There is a good handful of 88" 90" builds on xlforum right now. I believe you need good head work and big cams to take full advantage of those builds
Old 05-30-2013, 12:10 PM
motohaid's Avatar
motohaid
motohaid is offline
Hastings says they are to be used with Buell thunderstorm heads but sportster heads will work. You have to by stock sportster rods and they say the only other thing you need is that the case has to be bored for the bigger jugs. Stock cams should work but you are right, to take full advantage of the conversion new cams would be
needed.
Old 05-30-2013, 12:17 PM
jojoenglish85's Avatar
jojoenglish85
jojoenglish85 is offline
id rather buy a bigger bike, then you have two bikes to customize lol
Old 05-30-2013, 12:32 PM
rickss69's Avatar
rickss69
rickss69 is offline
Not a bolt-on, big money and lots of headaches.
Old 05-30-2013, 02:51 PM
motohaid's Avatar
motohaid
motohaid is offline
[QUOTE=jojoenglish85;11352932]id rather buy a bigger bike, then you have two bikes to customize lol[/QUOTE
Yeah, but I have always been kinda like Tim "TheToolMan" Taylor. Gotta give it more power. Besides a bigger bike is just a bigger bike. It may have a bigger motor but it won't handle like a sportster.
Old 05-30-2013, 02:58 PM
motohaid's Avatar
motohaid
motohaid is offline
You're right it is not a weekend project. The kit cost around 950.00 and you have to buy rods separately. The case has to be machined for the larger cylinder so the engine has to be completely disassembled. But it's something to ponder.
Oh yeah, stop teasing the rabbit.
Old 05-30-2013, 04:01 PM
mos68x's Avatar
mos68x
mos68x is offline
I'm glad you brought this up, I saw or heard someone else mention the 90" conversion for the 1200 but I didn't know how it was accomplished, thanks for educating me.
Old 05-30-2013, 04:31 PM
Madnss's Avatar
Madnss
Madnss is offline
Consider if you are splitting the cases.....assembly, disassembly, everything comes out of the engine, Tran and primary. The 88" 90" motors put out some very good tq numbers too. A hoot to ride. A cheaper version with less power, but still up there is a hot 1250 build. No bottom end work required. You can have it done in A/V weekend and not break the bank.
masterblaster
"The Florida Crew"
01-16-2012 09:15 PM
Patrick
08-01-2011 05:37 PM
eds06roadglide
02-11-2011 11:36 AM
Quick Reply: 90 inch Sportster?
