2013 XL1200C...Thinking about putting mini apes on my bike. Would I need longer cables? Just curious what or if there is anything I would need to modify. TIA for your replies.
Have you checked with the dealership about this? I talked to the folks in the parts dept about this same mod for my '07 Custom. The consensus was that I would need new cables. I never got around to the mod because it would have cost too much and I would have gotten to little return.
I asked this question a few days ago about my 08 nightster. The consensus I got was if the mini's were 8" or under the stock cables should fit... hope that's right cause mine are on the way.
on my "custom" i re used my stock stuff EXCEPT the brake line... that just wouldnt fit even with "bending it" i just RE routed the wires and Clutch and it all fit! BTW i installed 12in Mini Apes...
10 inch or longer u will want new cables and brake line - it will be tight an not alot of play
i have the hd chisled bars 10" and i opted for the cables an lines
On my '09 custom i only had to get a new brake line....however the control housing cables are a little stretched to the max, I have 10" road 6 customs bars. Heres a few views, hope it helps.
