Charging System Questions for a Sportster with a Generator
Old 07-02-2013, 11:32 AM
ih_power's Avatar
ih_power
ih_power is offline
Stage III
Thumbs down Charging System Questions for a Sportster with a Generator
My Bike - 1980 XLH 1000 Sportster. Uses a Generator, not an alternator. I have the Factory Service Manual and Factory Parts Catalog
I installed a cheapo automotive style voltage gauge on the Bike to try and get an early warning that the battery is going to die. No Kicker on my bike so it sucks when the Battery dies and I am out riding with no help close by. I know that this voltage gauge is not accurate, so don't pay too much attention to it most of the time.
Was running down the highway Sunday and glanced down at my gauges. Voltage Gauge showed almost 17 Volts. pulled over and let the bike idle. Voltage gauge went down to just under 12 Volts. Got back on the road. Any time I went over 40MPH, Voltage gauge over 14 Volts. Generator idiot light only comes on at Idle.
Read through the service maunal section covering the charging system. Scratched my head, I don't get it. Don't quite understand the info in the service manual.
Is there any easier way to check out the generator, volt regulator, etc to make sure it is not overcharging. Could get expensive if the charging system is overcharging and starts frying the other electrical systems on the bike.
Thanks!
ih_power
Old 07-02-2013, 11:40 AM
cHarley's Avatar
cHarley
cHarley is offline
Thanks!
ih_power
For starters, I'd suggest an ACCURATE, preferably digital, voltmeter, so you know whether or not you actually have a problem.
Old 07-02-2013, 12:34 PM
ih_power's Avatar
ih_power
ih_power is offline
Stage III
Any Suggestions as to which Digital Voltmeter to buy?
Frogprince
04-09-2024 10:08 AM
rhuff
09-17-2017 09:33 AM
TheBaron
09-04-2017 11:37 PM
TennesseeEG
04-05-2012 09:34 PM
acadien
08-21-2007 04:12 AM
Quick Reply: Charging System Questions for a Sportster with a Generator
