Stumped…. Please Help!!!
I have a 1989 Sportster Deluxe 883 that has been shutting off on me. It has happened 4 times in the past 2 months and so far nobody can figure out why. The Coil, plugs, & wires were changed and the petcock recently cleaned.
All 4 times have occurred within 10 minutes of my starting point and at speeds less than 25 mph. The bike just stalls and won’t restart. All of the lights are on and it tries to start but won’t kick over. Then after a while it starts up like nothing ever happened…
Ignition module would be next on my list.
If I recall correctly, when they start to go, the heat makes it worse...so they heat up, stop working, you shut off the bike, they cool down...bam working again until you heat the bike back up.
You can get a can of electronics freeze spray, and hit the ignition module with it when the bike is hot and won't run, if it immediately starts back up, you found your problem.
Hey - not all that familiar with the 89's but what type of fuel pump do you have? Reason I ask is that I had a similar issue with my Sporty and ultimately found the little screen in my fuel pump was gummed up. I actually replaced it versus cleaning it and never had the problem again. Not sure if that is relevant to your situation or not, but thought I'd throw it out there.
Good luck!
Good luck!
I know this is silly but...have you double checked the connections at your battery and the ground strap to the frame?
Good luck!
Good luck!
You are correct Thumper. The 89 sportster does not have a Fuel pump. I also agree with the ingintion being the problem, but also check you fuel cap if it is partly plugged it will do that to. Sometimes it will run with out isue than others it will shut down. When your bike does this next time try cracking the fuel cap and see if it starts. i had this same thing happen to my 88 but I have the fat bob tank on it.
Received 3,930 Likes
Click HERE for a link to a diagram of your electronic control module.
The older Sportys have issues with the main circuit breakers working intermittently prior to complete failure.
Click HERE for a link that will help.
Well, for some reason HD Forum is truncating the links and they are not working.
Here they are, you will need to put a
http:// in front of the following to get it to come up
partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?Type=13&make=hdmc&a=93&b=11&c=0&d=-ELECTRICAL---ELECTRONIC-CONTROL-MODULE-W/-COIL-ASSEMBLY
and the same with this one-
partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?Type=13&make=hdmc&a=93&b=44&c=0&d=-ELECTRICAL---SWITCHES-AND-CIRCUIT-BREAKERS
