Switching to Digital Speedo/Tachometer -- looking for Data Link Connector?
Hey I just purchased a new digital speedometer/tachometer for my 2012 Seventy Two, the picture in the instruction showing the Data Link Connector [91] and Rubber Plug are terrible quality.
Where is the data link connector and rubber plug located? I need to copy the odometer to the new speedo before plugging it in to the stock harness...
Thanks in advance!
Thanks in advance!
I've answered your pm's.....but just to be sure, here's a youtube video that helped me a lot:
. Its the 5 inch speedo on a Fat Bob but the process is the same. Its an easy install IF YOU FOLLOW THE INSTRUCTIONS. I rushed it and did not clear some old diagnostic codes first and the first try on setting up the new speedo at the data port failed. Redid it once I had cleared the codes and it was fine. And I first thought the mileage copied over wrong but by default it showed miles and my original speedo is kilometers (Canada)
I've answered your pm's.....but just to be sure, here's a youtube video that helped me a lot: Harley Davidson Gauge Upgrade - YouTube. Its the 5 inch speedo on a Fat Bob but the process is the same. Its an easy install IF YOU FOLLOW THE INSTRUCTIONS. I rushed it and did not clear some old diagnostic codes first and the first try on setting up the new speedo at the data port failed. Redid it once I had cleared the codes and it was fine. And I first thought the mileage copied over wrong but by default it showed miles and my original speedo is kilometers (Canada)
Now i just gotta play around and figure how to switch from MPH to KMH
rgb66
Electrical/Lighting/Alarm
07-21-2019 06:13 PM
