Bike just clicks wont start
Old 08-02-2013, 08:50 AM
Frank Gomez's Avatar
Frank Gomez
Frank Gomez is offline
Stage III
Default Bike just clicks wont start
Hello. I have a 2008 Nightster. Today I tried to start the bike and it just clicked. It was working fine a week ago.
I read about cleaning the battery cables. and the ground wire. I will try to do that tonight. Someone also spoke about cleaning the wire that goes to the starter selenoid. Where is this located and how do I clean it?
Is there any other possible problems? The battery is not that old.
Old 08-02-2013, 09:06 AM
samhallnc's Avatar
samhallnc
samhallnc is offline
probably just need to tighten the battery cables up. I wouldn't look further till you rule that out.
Old 08-02-2013, 09:12 AM
cHarley's Avatar
cHarley
cHarley is offline
I'd start by measuring the battery voltage. If it's less than 12.6 volts it needs charging or has gone bad.
Old 08-02-2013, 09:35 AM
parabellum_9x19's Avatar
parabellum_9x19
parabellum_9x19 is offline
Ditto to both of the above comments.
Verify the battery is charged and verify that the connection between the battery and the bike is good on all points.
Old 08-02-2013, 10:09 AM
ironcrab's Avatar
ironcrab
ironcrab is offline
I had same issue on my 09 Iron last year. Did all the battery cable checks. Mine turned out to be a relay. I changed both and haven't had issue again.
Old 08-02-2013, 10:20 AM
abeldiazjr's Avatar
abeldiazjr
abeldiazjr is offline
Default Charge your battery
Sounds like a battery with low voltage. Invest in a battery tender for those long periods of no riding.
Old 08-02-2013, 10:26 AM
cHarley's Avatar
cHarley
cHarley is offline
Originally Posted by abeldiazjr
Sounds like a battery with low voltage. Invest in a trickle charge for those long periods of no riding.
A Trickle charger should not be used to "maintain" a battery, it will literally cook the battery.
You should use a Float charger which is often referred to as a Battery Tender.
Old 08-02-2013, 10:30 AM
parrishbjj's Avatar
parrishbjj
parrishbjj is offline
This is what I have been following to get an 82 shovel up and running.
http://www.classiccycles.org/media/D...12ffffe41e.pdf
If all the pages dont open up correctly, click the button that says Open With Different Viewer on the top right of the page. have fun!
Old 08-02-2013, 01:32 PM
Roni's Avatar
Roni
Roni is offline
If the cable and battery suggestions don't work, try tapping firmly on the solenoid with the handle of a BFS (Big Scredriver) while trying to start the bike. If this works, your solenoid might be going bad.
Old 08-02-2013, 01:37 PM
mikek87's Avatar
mikek87
mikek87 is offline
And if this doesn't work break out the BFH ( big fing hammer) and go to town. This is usualy my tool of chose when things don't go right.
Quick Reply: Bike just clicks wont start
