Keihin butterfly carb tuning
Old 08-07-2013, 08:36 AM
vintagebikes's Avatar
vintagebikes
vintagebikes is offline
Default Keihin butterfly carb tuning
For any other old school guys out there.
Someone should make this a sticky
https://www.hdforums.com/forum/engin...rfly-carb.html
Followed his advice, my 87' Sporty 883 runs amazing. Throttle response is awesome and its much quicker. Also helped that I replaced the old intake manifold gaskets and put in a phenolic carb spacer.
My specs are up one size on the pilot jet 52 to 54, 1 turn open on the mixture screw, stock main jet 155, and Andrews accelerator pump. Dennis Kirk had it all in stock as well as the James spacer kit.
Old 08-08-2013, 04:03 PM
83XLX's Avatar
83XLX
83XLX is offline
I've done all those performance mods, but sort of discovered them on my own over a few years of tinkering. I also fitted a Screamin' Eagle air cleaner assembly, and since the choke was barely needed, I removed the choke shaft and plate from the mouth of the carb to increase airflow. A couple squirts from the accelerator pump and it starts right up. I left the fast idle linkage in place (controlled by the choke ****), so I can bump the idle up a bit until it warms up in colder weather.
1/2crazedbikr
EVO
15
12-10-2022 03:59 PM
frankjc
Carburetor Related
09-27-2017 09:17 PM
buellxb422
Ironhead
04-25-2016 08:13 AM
das56170
EVO
12-28-2015 08:56 AM
brwdarr
EVO
39
08-20-2010 07:58 PM
Quick Reply: Keihin butterfly carb tuning
