Correct installation of new brake light on chopped fender...
hey everyone,
i'd like to install a new tail light on my choppped sporster fender and also retain the use of the signal lights. the kit didnt come with instructions and now a few questions are popping up, it looks like there are a couple different ways to do this..
im also curious about a couple of mystery harnesses, one is capped and the other is not- im assuming they are for other accessories?
the kit i got is this one:
http://www.dragspecialties.com/produ...&submit=Search
as you can see it comes with a harness that is meant to plug in at the main lighting harness under the seat + attach new light. the issue is that the new harness that comes with the kit does not have slots to plug the OEM turn signals.
the turn signals originally plugged into the bracket harness behind the OEM tail light (which is no longer on the bike because it was chopped)...
so there seems to be a couple options, and perhaps there are some fixes / special harness that have been created already that im unaware of..
should i ditch the new tailight harness altogether and re-use the OEM bracket harness? just plug the new tail light directly into that and hide it up under the fender?
is there a special tail light wire harness i should be using to avoid having to reuse the OEM bracket harness from the tail light?
what would you do?! what have you done? thanks so much!
i tried to document what im dealing with best i can with pictures, hope it helps
I have the same setup on my chopped fender. I cut the wires to the blinkers and wired them from the harness under the seat directly to the signals. I got rid of the wires that used to plug in to the old brake light. I then used the harness that came with the 3rd brake light and plugged in inline with the harness under the seat per the instructions. This way, I only had 4 turn signal wires to solder and my cuts were on the fender side of the harness. This way the factory plug stays in tact under the seat. Make sense?
thanks, theres no siren or alarm set up on the bike right now. i'd like to avoid cutting into the factory wiring if possible
heres how the bike was situated before the fender was chopped... the main lighting harness is of course located under the seat, which then leads through a grommet in the fender and into a rubber tube along the top of the fender back to the brake light assembly. in all, 1) the main lighting harness, 2) the brake light, 3) both turn signals plugged into the brake light assembly.
so essentially after chopping the fender and using the provided inline harness for the new tail light there is nowhere to plug the OEM rear turn signals UNLESS i repurpose brake light assembly harness bracket.
id really like to avoid cutting into factory wiring as well as cutting the connectors off the OEM signals
hey dallas thanks so much for the info. im trying my best to follow, but im unsure of a couple things.
